This is a database showing devices tested to work on Toradex's hardware. For more information, use the filters to select a device and click its name to head to its specific page.
Type | Interface | Features | Manufacturer | Device |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | LSR | 001-0012 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Molex | 146153-1100 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Molex | 204281-1100 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Unictron | AA222 MHF4 |
Wifi Adapter | USB | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n | TP-Link | Archer T2U Nano AC600 |
Wifi Adapter | SDIO | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n, Includes Bluetooth | Azurewave | AW-CM276NF |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n, Includes Bluetooth | Azurewave | AW-CM389NF |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Chang Hong | DA-2458-02 RP-SMA |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 a/b/g/n, Includes Bluetooth | u-blox | ELLA-W1 |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n, Includes Bluetooth | u-blox | EMMY-W1 |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Taoglas | GW.59.3153 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Unictron | H2B1PD1A1C385L |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Laird | MAF94051 |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n, Includes Bluetooth, Includes NFC | H&D Wireless | SPB209A |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n, Includes Bluetooth | Silex | SX-SDCAC |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Wi2Wi | WADB-2458-23-SMAM |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 a/b/g/n, Includes Bluetooth | Texas Instruments | WL18xx |
Wifi Adapter | SDIO (SMT Module) | 2.4 GHz, 5 GHz, 802.11 ac/a/b/g/n, Includes Bluetooth | Wi2Wi | WM828CC6 |
Wifi Adapter | USB | 2.4 GHz, 5 GHz, 802.11 b/g/n | SparkLAN | WUBR-508N |
