Manufacture: | Wi2Wi |
Device Type: | Wifi Adapter |
Interface: | SDIO (SMT Module) |
Features: | 2.4 GHz 5 GHz 802.11 ac/a/b/g/n Includes Bluetooth |
Hardware / Firmware Version | Module (Version) | Board (Version) | OS (OS / BSP Version) | Note | Test Date |
No results found. |
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / - | Any Module (Any Version) | Any Carrier Board (Any Version) | Yocto (Linux) (Any) | - |
