001-0012 - LSR
Manufacture: LSR
Device Type: Antenna
Interface: Dipole
Features: 2.4 GHz
5 GHz
CE (EEA)
FCC (USA)
IC (Canada)
SMA
TELEC (JAPAN)
WPC (India)
Device Page
Compatible Setups
No results found.
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / -Any Apalis Module (Any Version)Any Carrier Board (Any Version)TorizonCore (Linux) (Any) -
- / -Any Colibri Module (Any Version)Any Carrier Board (Any Version)TorizonCore (Linux) (Any) -
- / -Any Apalis Module (Any Version)Any Carrier Board (Any Version)Yocto (Linux) (Any) -
- / -Any Colibri Module (Any Version)Any Carrier Board (Any Version)Yocto (Linux) (Any) -
- / -Any Apalis Module (Any Version)Any Carrier Board (Any Version)WEC (Any) -
- / -Any Colibri Module (Any Version)Any Carrier Board (Any Version)WEC (Any) -
Antennas sold by Toradex are independent of software and they can be used on all Toradex SoMs that have Wi-Fi/Bluetooth integrated module, pleaser refer to Toradex Modules with Integrated Wi-Fi/Bluetooth to know more about. Antennas sold by Toradex can also be used on Wi-Fi/Bluetooth compatible modules on a customized carrier board, as long as they do meet the specific criteria of the device chosen by the customer - in which case it is the customer responsibility to assure it.
Datasheet
