Manufacture: | Chang Hong |
Device Type: | Antenna |
Interface: | Dipole |
Features: | 2.4 GHz 5 GHz CE (EEA) FCC (USA) IC (Canada) SMA TELEC (JAPAN) WPC (India) |
Hardware / Firmware Version | Module (Version) | Board (Version) | OS (OS / BSP Version) | Note | Test Date |
No results found. |
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / - | Any Apalis Module (Any Version) | Any Carrier Board (Any Version) | TorizonCore (Linux) (Any) | - | |
- / - | Any Colibri Module (Any Version) | Any Carrier Board (Any Version) | TorizonCore (Linux) (Any) | - | |
- / - | Any Apalis Module (Any Version) | Any Carrier Board (Any Version) | Yocto (Linux) (Any) | - | |
- / - | Any Colibri Module (Any Version) | Any Carrier Board (Any Version) | Yocto (Linux) (Any) | - | |
- / - | Any Apalis Module (Any Version) | Any Carrier Board (Any Version) | WEC (Any) | - | |
- / - | Any Colibri Module (Any Version) | Any Carrier Board (Any Version) | WEC (Any) | - |
Antennas sold by Toradex are independent of software and they can be used on all Toradex SoMs that have Wi-Fi/Bluetooth integrated module, pleaser refer to Toradex Modules with Integrated Wi-Fi/Bluetooth to know more about. Antennas sold by Toradex can also be used on Wi-Fi/Bluetooth compatible modules on a customized carrier board, as long as they do meet the specific criteria of the device chosen by the customer - in which case it is the customer responsibility to assure it.
