This is a database showing devices tested to work on Toradex's hardware. For more information, use the filters to select a device and click its name to head to its specific page.
Type | Interface | Features | Manufacturer | Device |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | LSR | 001-0012 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Molex | 146153-1100 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Molex | 204281-1100 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Unictron | AA222 MHF4 |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Chang Hong | DA-2458-02 RP-SMA |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Taoglas | GW.59.3153 |
Antenna | PCB | 2.4 GHz, 5 GHz, Cable length (100mm), CE (EEA), FCC (USA), IC (Canada), MHF4, TELEC (JAPAN), WPC (India) | Unictron | H2B1PD1A1C385L |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Laird | MAF94051 |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Wi2Wi | WADB-2458-23-SMAM |
