Customizing Kernel Arguments in Torizon
Article updated at 17 Mar 2021
Torizon 5.2.0
The Linux Kernel of TorizonCore accepts certain boot-time arguments (parameters) that configure aspects of the kernel itself or its modules. This article briefly describes the method provided by the TorizonCore Builder tool (which is part of the Torizon platform) to perform such configuration.
To learn which Linux Kernel version corresponds to the latest TorizonCore versions, check the Embedded Linux Release Matrix.
To find out more about Linux Kernel Arguments, see The kernel’s command-line parameters.
Pre-requisites
The pre-requisite to complete these instructions are:
Create and enter a working directory where your customization will be stored:
$ mkdir ~/tcbworkdir
$ cd ~/tcbworkdir
Use the setup script named tcb-env-setup.sh, available on the Toradex Github, to setup TorizonCore Builder:
$ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
$ source tcb-env-setup.sh
For advanced usage, run source tcb-env-setup.sh -h, or see the project README.
If using Windows, you must pass extra parameters to the script when using the following commands:
Tip: The setup script installs a bash completion script for TorizonCore Builder, making it possible to autocomplete commands and parameters by just pressing the TAB key.
Verify that the command torizoncore-builder is available:
$ torizoncore-builder --help
Warning: Make sure to: (1) source the script, (2) every time you open a new terminal, (3) inside the working directory you have previously created. Otherwise, it will not work as intended and, most importantly, the torizoncore-builder alias will not be created properly.
Applying Kernel Arguments to a Custom Image
Attention: Both approaches generate a custom Toradex Easy Installer image as output, so the approaches should be followed alternatively and not in sequence.
Approach 1: Applying Custom Kernel Arguments to a Custom Image Using the Build Command
TorizonCore Builder build command generates a custom TorizonCore image with the custom kernel arguments applied, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yaml as default.
It requires a Toradex Easy Installer image of TorizonCore (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The directory with the kernel arguments are passed as customization: kernel: arguments.
tcbuild.yaml
# Sample configuration file:
input:
  easy-installer:
# Sample customization: include or change (if already exists) key1 and key2 kernel arguments
customization:
  kernel:
    arguments:
      - key1=val1
      - key2=val2
output:
  easy-installer:
Build The Custom Image
To generate the TorizonCore image, run the command below, in the same directory where the tcbuild.yaml file is:
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
Approach 2: Applying Custom Kernel Arguments to a Custom Image: Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom TorizonCore with the custom kernel arguments is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with different custom kernel arguments (or other customizations like different device tree overlays). As you will see, applying custom kernel arguments on an image of TorizonCore that has other customizations is just a matter of performing the apply, merge and deploy stages.
To generate a custom Toradex Easy Installer image with the desired custom kernel arguments follow the sequence of steps below.
Unpack an Input Image
You just need to execute this once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying custom kernel arguments, you can also apply a custom splash screen, a new device tree, among other possibilities.
If you have not unpacked an image yet, download a base TorizonCore image (preferably without containers) inside the TorizonCore Builder working directory, then run the command below to unpack it. In the example below the torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar image is used as a reference:
If you want to change the TorizonCore base image, download the new image and run the images unpack command again, passing the new image as the argument.
Instead of using the images unpack you can use the images download command. This command checks which is the connected Toradex SoM, downloads the compatible latest quarterly release of a TorizonCore image without containers, and unpacks this image.
Set A Custom Kernel Argument
For setting the custom kernel arguments, one would simply run:
$ torizoncore-builder kernel set_custom_args "key1=val1" "key2=val2"
'custom-kargs_overlay.dts' compiles successfully.
Overlay custom-kargs_overlay.dtbo successfully applied.
Kernel custom arguments successfully configured with "key1=val1 key2=val2".
Warning: Every time you execute the kernel set_custom_args command the custom-kargs_overlay.dts is overwritten, so you should pass all the kernel arguments in a single set_custom_args command.
For more details about the kernel set_custom_args command, please check the kernel set_custom_args command in the commands manual.
As shown in the above message, a device tree overlay will be applied to the image to set the custom arguments. This fact can be verified by using the dto status command, which will display the custom-kargs_overlay.dtbo amongst any other applied overlays, like so:
$ torizoncore-builder dto status
Enabled overlays over device tree imx6dl-colibri-eval-v3.dtb:
- colibri-imx6_parallel-rgb_overlay.dtbo
- colibri-imx6_stmpe-ts_overlay.dtbo
- display-vga_overlay.dtbo
- custom-kargs_overlay.dtbo
Warning: Since the arguments are kept in a device-tree overlay, the user should be careful not to remove that overlay (especially by using dto remove --all) or the arguments will not be present on the deployed image.
For more details about the dto status command, please check the dto status command in the commands manual.
Check The Current Set Of Custom Kernel Arguments
To determine what the current custom kernel arguments are (that is, what configuration would take effect upon the execution of a union command) use:
$ torizoncore-builder kernel get_custom_args
Currently configured custom kernel arguments: "key1=val1" "key2=val2".
For more details about the kernel get_custom_args command, please check the kernel get_custom_args command in the commands manual.
Finally, it is also possible to clear any applied custom kernel arguments by doing:
$ torizoncore-builder kernel clear_custom_args
Custom kernel arguments successfully cleared.
This will remove the corresponding device-tree overlay (custom-kargs_overlay.dtbo) as done by dto remove.
For more details about the kernel clear_custom_args command, please check the kernel clear_custom_args command in the commands manual.
Merge Changes
Merge the kernel arguments (as well as other customizations like a splash screen or a new device tree) into the base Toradex Easy Installer image of Torizon - use whatever branch name you want.
$ torizoncore-builder union --union-branch=custom-branch
Warning: We recommend that you switch to the latest version of TorizonCore Builder to enjoy its simpler and more consistent user interface besides other improvements and bug fixes.
Verifying The New Custom Image On The Device
After rebooting, in your target device's terminal, verify that your new custom image of TorizonCore is active on the device with the command below:
# sudo ostree admin status
Password:
Check The Custom Kernel Arguments
After deploying the image, you should be able to see your custom kernel arguments in the kernel arguments list. To do it, you can use the command below:
# cat /proc/cmdline
enable_wait_mode=off galcore.contiguousSize=50331648 root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash ostree=/ostree/boot.1/torizon/248c1906ffb097b9d5dd4d48f0a942a23cfd82378649edbc24ce5743291c53b0/0 key1=val1 key2=val2
