WCL-1198 | Fixed | RPMSGLib MessageBuffer can get out of sync | | M4 | CE6, WEC7, WEC2013 |
Description: Due to a missing critical section the MessageBuffer of the RPMSGLib can get out of sync and corrupted data will be read or written. This typically happens in heavy messaging situations and is only happening sporadically. |
WCL-1197 | Fixed | Added support for FlashFileSystem Wipe in UpdateTool / UpdateLib for Vybrid | | Flash | CE6, WEC7, WEC2013 |
Description: - Added Upd_EraseFilesystem() to UpdateLib
- Added /w command line param to UpdateTool (/wu for unattended or /wb for wipe also blocks marked as bad) |
WCL-1196 | Fixed | UpdateLibrary for iMX6 is not HAB compatible | | Bootloader | WEC7, WEC2013 |
Description: Trying to restore a HAB (SecureBoot) SPL or Bootloader will fail because of alignment constraints |
WCL-1195 | Fixed | Some UpdateTool operations on Vybrid lead to freeze | | Update System | CE6, WEC7, WEC2013 |
Description: Updateting Bootloader, Spashscrren or ConfigBlock while some flashfilesystem operations are in progress can freeze both the update tool and the filesystem |
WCL-1194 | Fixed | Re-Initializing CAN Library could freeze the system | | CAN | CE6, WEC7, WEC2013 |
Description: When calling again Can_Init() after Can_DeInit() it can happen that the system freezes because can interrupts could be triggered while initializing the library btu before proper interrupt handling has been set-up. |
WCL-1193 | Fixed | Watchdog Library does not work on iMX7 | | Watchdog | CE6, WEC7, WEC2013 |
Description: Imx7Wdg_Init() fails as it tries to open "I2C4" instead of the internal "I2C9" that is connected to the PMIC |
WCL-686 | Fixed | CanLib: Exception Thrown When Intializing CanLib | Colibri VF50, Colibri VF61 | CAN | WEC2013 |
Description: Can_Init() generates an exception when run on a VFxx module under WEC2013.
The same code is working well under CE6 and WEC7. Workaround: Ask Toradex support for a preliminary version of the libraries including a fix for this issue. |
WCL-653 | Fixed | IMX6 CAN error and system freeze when calling CAN_Read after CAN_Close | Colibri iMX6 | Bluetooth, CAN | WEC2013 |
Description: Wait for CAN_Read before calling CAN_Close |
WCL-609 | Fixed | CAN C# interface does not return proper values | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: CanLib functions return wrong values when used from C#. |
WCL-608 | New Feature | Document and optimize shared resources for the rpmsg library | Colibri iMX7, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Adjust number of buffers for the rpmsg protocol on the i.MX7 |
WCL-605 | Fixed | UpdateLib for iMX6: Update OS fails if CPU is loaded | Apalis iMX6 | WinCE Feature | WEC7 |
Description: Updating OS fails if CPU is heavily loaded |
WCL-603 | Fixed | GpioLib for iMX7: Mapping of SODIMM 77 is wrong | Colibri iMX7 | GPIO | CE6, WEC7, WEC2013 |
Description: On Colibri iMX7, SODIMM pin 77 cannot be accessed using the Gpio Library. Workaround: Write your code to use GPIO 176, which is identical to SODIMM 77 for Colibri iMX7. |
WCL-602 | Fixed | The resistive touch stops working after calling Adc_Deinit() | Colibri iMX6 | Analog Inputs | WEC2013 |
Description: The resistive touch stops working after De-Initializing the Adc library. |
WCL-600 | Fixed | I2CLib - Unlocking I2C bus after module reset does not work | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: The I2C library tries to "unlock" I2C bus if a slave device is not releasing the SDA signal, this may happen if the module is reset in the middle of an I2C transaction when the slave device has control of SDA line. Workaround: Issue has been fixed. |
WCL-597 | Fixed | Spi CS default state is Low till first SPI transfer starts | Colibri iMX7 | SPI | WEC7, WEC2013 |
Description: After a power cycle, the ~CS pin of the SPI interface is low, which is wrong as ~CS low is the active state. After a power cycle, this pin should be high in all cases. Workaround: Use latest libraries and BSP above 1.2b4 |
WCL-591 | New Feature | Update library release process | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Miscellaneous Peripherals | CE6, WEC7, WEC2013 |
Description: A 32-bit hash is used to represent the library build number, which can be queried by calling xxx_GetVersion(). In contrast to previous library versions, the build number is not increasing for newer library versions, but must be treated as a random 32-bit number. |
WCL-590 | Fixed | CAN on i.MX6 blocks on simultaneous read/write | Apalis iMX6 | CAN | CE6, WEC7 |
Description: Can issues when sending and receiving in parallel threads |
WCL-589 | Fixed | I2c lib APIs not working when calling from Kernel driver. | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: I2cTransaction calling through kernelCallback. Kernelcallback doesn't seems to be working from kernel driver. |
WCL-588 | Fixed | Simplify and stabilize Rpmsg C# demo | Colibri iMX7, Colibri VF61 | Miscellaneous Peripherals | CE6, WEC7, WEC2013 |
Description: Fix RpMsg demo for C# |
WCL-585 | Fixed | UpdateTool cannot flash splashscreens wider than 1080 pixels | Colibri iMX7, Apalis iMX6, Colibri iMX6 | Toradex Feature, Update System | WEC7, WEC2013 |
Description: Large Splashscreen cannot be programmed using the UpateTool Workaround: Use bootloader command flashsplash or Toradex Easy Installer to load the splashscreen |
WCL-582 | New Feature | Document DRAM allocated to rpmsg | Colibri iMX7, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Document memory allocated to RpMsg |
WCL-577 | Fixed | CanLib: Transmitting message of 0 bytes length causes division-by-zero | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE5, CE6, WEC7, WEC2013 |
Description: Sending zero-length CAN messages can cause an error message "Division by zero". |
WCL-574 | Fixed | RpMsgLib: Add timeout to function MU_SendMsg() | Colibri iMX7, Colibri VF61 | CPU | CE6, WEC7, WEC2013 |
Description: RpMsg_Open() hangs, if the M4 firmware does not process messages. |
WCL-561 | Fixed | Spi_Read and SpiWrite are not calling IMX7 platform specfic APIs | Colibri iMX7 | SPI | WEC7, WEC2013 |
Description: The generic Spi_Read and Spi_Write are not calling iMX7 platform-specific APIs. |
WCL-559 | Fixed | CanLib for iMX6: Possible loss of received message | Colibri iMX6 | CAN | CE6, WEC7, WEC2013 |
Description: Sometimes a CAN message is not received by the CAN library. |
WCL-556 | New Feature | Can Library for MCP2515: Make interrupt thread priority configurable | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: Implement a parameter istPriority to configure the priority of the interrupt thread, which reads messages from the MCP2515 controller. |
WCL-555 | Fixed | I2cLib speed setting 400Khz doesn't apply | Colibri iMX7, Apalis iMX6, Colibri iMX6 | I2C | WEC7, WEC2013 |
Description: Default I2c speed of 100Khz is always used even when set to 400Khz through library APIs. |
WCL-554 | Fixed | I2CLib on Tegra does not do a I2CBus reset on first init | Colibri T20, Colibri T30 | I2C | CE6, WEC7, WEC2013 |
Description: From Library version 2.1, no I2C Bus reset is sent anymore. If there is a malfunctioning device or a device was in the middle of a transfer and a system reset was done which the device does not see, I2C communication could be malfunctioning |
WCL-553 | Fixed | Slow ADC Read on T30 | Colibri T30, Apalis T30 | Analog Inputs | WEC7, WEC2013 |
Description: We have observed slow ADC reading, a couple of libraries were loading and unloading for everytime I2c open and close APIs are calling, it is taking additionally 8ms to 15ms for each ADC read. We moved library loading and unloading to Init and DeInit and it is saving the time. |
WCL-549 | New Feature | ConfigBlock Usage Documentation | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | ConfigBlock | CE5, CE6, WEC7, WEC2013 |
Description: Add documentation about how to read/write data from/to the ConfigBlock, e.g. Hardware ID and version, MAC address, user data. |
WCL-670 | Fixed | SpiLib: Documentation of used wait method is misleading | Apalis iMX6, Colibri iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: Adjust documentation of the wait method in Spi_ReadWrite() for iMX6 |
WCL-659 | Fixed | Compiler / Linker Incompatibilities | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Buildsystem, Toradex Feature | CE6, WEC7, WEC2013 |
Description: The Linker reports errors about mismatched versions of compiler / linker, when building an application in RELEASE configuration.
This is caused by an optimization "Link Time Code Generation" which we enabled for building the libraries V2.1. Workaround: Use the Toradex CE Libraries in DEBUG configuration, or restore the old compiler which Microsoft stored at
C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\ce\bin\x86_arm\KB2921525_BACKUP\ |
WCL-654 | Fixed | GetVersion() SoC specific function missing in some library | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Upd_GetVersion() SoC specific function ( eg. Imx6Upd_GetVersion for IMX6) are not available for update library Workaround: Use the common function - Upd_GetVersion() |
WCL-651 | Fixed | CanLib for MCP2515: Writing a CAN message with 0 data bytes generates an exception | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | CAN | CE6, WEC7, WEC2013 |
Description: When sending a CAN message with 0 length, the Toradex function @Can_Write()@ crashes with a divide by zero exception. |
WCL-650 | Fixed | SysInfoLib: documentation of parameter BspVersion.BspId is incorrect | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: The library help file V2.2 and before reports the interpretation of the BspVersion.BspId incorrectly. Correct is: 0=Unknown, 1=PXA, 2=Tegra, 3=Vybrid, 4=Imx6, 5=Imx7 Workaround: Ignore the help file. The implementation in the SysInfo_Demo is correct. |
WCL-648 | New Feature | Improve .NET definition for xxx_GetConfigString | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: Change the definition of xxx_GetConfigString() functions |
WCL-647 | Fixed | SPI : Packed Mode not working on Vybrid | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: Packed Mode not working on Vybrid |
WCL-646 | Fixed | Context Corruption in Toradex CE library | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN, I2C, Toradex Feature | CE6, WEC7, WEC2013 |
Description: Library hits breakpoint with warning "SYS Error: .\src\config_parser.c, 434: Context Corruption" or similar. Affected libraries are SysInfo, Can, i2c and RpMsg. Workaround: Will be solved in library package V2.3 |
WCL-645 | Fixed | I2cLib for Tegra: signed 16-bit addresses aren't supported | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Using a 16-bit i2c RegisterAddress fails, if the actual address is stored in a 16-bit *signed* variable. Workaround: Use a 32-bit or 16-bit unsigned variable to store the RegisterAddress. |
WCL-613 | Fixed | TdxAllLibrariesDll.cs is missing some SOC specific functions | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: Some SOC specific functions are missing in TdxAllLibrariesDll.cs. One is for example CAN functions for IMX6. Workaround: Use the genric functions or add the missing functions to the cs file on your own. |
WCL-610 | Fixed | SPI_Write on vybrid still collects input data | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: After a SPI_Write operation, up to 4 bytes of data may be stored in the RX FIFO and will be returned from a further SPI_Read or SPI_ReadWrite operation. Workaround: Always use SPI_ReadWrite, providing a dummy buffer to store data received during transmission. |
WCL-578 | New Feature | SpiLib for iMX7: Evaluate possible SPI clock frequencies | Colibri iMX7 | SPI | CE6, WEC7, WEC2013 |
Description: The documentation of the SPI library does now list all possible clock rates for the iMX7. |
WCL-575 | Fixed | Tegra SPI : Packed mode issue | Colibri T20, Colibri T30, Apalis T30 | SPI | CE6, WEC7, WEC2013 |
Description: Packed mode was working only with DMA Mode and DMA Mode was only working for transfers larger than 32 packets.
This is now fixed and Packed mode is supported in both DMA and PIO modes. |
WCL-573 | Fixed | RpmsgLib for iMX7: WinCe can hang in Rpmsg_Open() | Colibri iMX7 | CPU | CE6, WEC7, WEC2013 |
Description: If the M4 firmware does not turn on the clock for the MU-A peripheral (in CCGR39), Rpmsg_Open() will hang. Workaround: Enable the clock for MU-A before calling Rpmsg_Open() |
WCL-569 | Fixed | PWMLib on Tegra hangs system when using multiple PWM channels and closing one | Colibri T20, Colibri T30, Apalis T30 | PWM | CE6, WEC7, WEC2013 |
Description: Calling Pwm_Close() on one PWM channel will disable clocks for all PWM channels and will make system hang when trying to access PWM registers. This has now been fixed: common PWM Clock is not disabled in Pwm_Close() anymore Workaround: Do not call Pwm_Close() if you're still using another channel |
WCL-568 | Fixed | PWMLib on Tegra uses wrong duty cycle percent mapping | Colibri T20, Colibri T30, Apalis T30 | PWM | CE6, WEC7, WEC2013 |
Description: duty parameter in TegPwm_SetPwm() is mapped wrongly (0 = 0% ... 256 = 100%) but should be (0 = 0% ... 65536 = 100%) |
WCL-567 | Fixed | PWMLib on Tegra may hang system if PWM_Open() is called right after a PWM_Close() call | Colibri T20, Colibri T30, Apalis T30 | PWM | CE6, WEC7, WEC2013 |
Description: Calling open just after a close call could hang the system. Workaround: Keep the PWM instance open all the time. |
WCL-566 | Fixed | CAN_Write() and CAN_Read() cannot be called in parallel from 2 threads | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: Until now CAN_Read() and CAN_Write() were serialized, so even from 2 Threads only one of the two operations is possible at the same time. Since the CAN_Read() can be used to wait for messages with a timeout all writes would be blocked for that amount of time. This behavior has now been changed so that CAN_Write() is possible even while a CAN_Read() is in progress |
WCL-565 | Fixed | RpmsgLib for iMX7: M4 is not properly reset | Colibri iMX7 | Cache, Miscellaneous Peripherals | CE6, WEC7, WEC2013 |
Description: Restarting the M4 platform by closing and re-opening the RpMsgLib will result in unpredictable behavior of the M4 Workaround: This is fixed in library V2.3 or later |
WCL-564 | Fixed | Library release script does skip .NET demos | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: .NET demo code was missing in the library package |
WCL-550 | Fixed | UpdateLib: filesystem update on IMX6 and IMX7 with eMMC can damage registry and OS image | Apalis iMX6, Colibri iMX6 | Flash | CE6, WEC7, WEC2013 |
Description: The procedure delete and re-creates partitions but, since it's not possible to specify an offset, the new partition will overlap with the area used for registry and OS image. The device may keep working as expected, until sectors from registry or images are reclaimed by filesystem. |
WCL-470 | Fixed | WdgLib: Documentation of DeInit() Wrong | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Watchdog | CE6, WEC7, WEC2013 |
Description: Documentation of Deinit function is not precise. Disabling Watchdog is possible on some platforms (e.g. T20 and T30). We will update the documentation accordingly. |
- Added VS2015 Project, Solution and PropertySheet Files - Improved CAN Library - Improved Update Library (iMX6/iMX7) - Added Support for iMX7 in RPMsg Library - Improved SPI Library on iMX6 |
WCL-929 | New Feature | Allow setting polarity for SPI CS | Apalis iMX6, Colibri iMX6 | SPI | WEC7, WEC2013 |
Description: Allow setting polarity for SPI Chip Select. |
WCL-795 | Fixed | Call to Spi_SetConfigString on Vybrid may lead to unexpected behaviours | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: SPI library does not support string parameters but the strings passed in for valid int parameters are processed as integer values and this may lead to some unexpected behaviours for the library. Workaround: Don't call Spi_SetConfigString and use Spi_SetConfigInt instead. |
WCL-720 | New Feature | ADC library for VF50 and VF61 can't read temperature sensor | Colibri VF50, Colibri VF61 | Analog Inputs | CE6, WEC7, WEC2013 |
Description: Internal temperature value can now be read by opening "ADC99" library port |
WCL-703 | New Feature | Provide filesystem backup/restore in update library | Apalis iMX6, Colibri iMX6 | Toradex Feature | WEC7, WEC2013 |
Description: Currently, this feature is implemented on Vybrid, only on CE7. |
WCL-669 | New Feature | Cleaned up UpdateLib_Demo | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Made the UpdateLib Demo easier to understand. |
WCL-663 | Fixed | CanLib: Several Functions ..._Int() are not marked as 'static' | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: (internal cleanup) |
WCL-661 | New Feature | UpdateLib on Vybrid: Added Feature to Erase Filesystem | Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Added a function to erase the filesystem region (/FlashDisk/) |
WCL-658 | Fixed | Allow I2c_Write with 0 bytes length. | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Allow I2c_Write with 0 bytes length.
NOTE: This is still not allowed on Tegra Modules |
WCL-644 | Fixed | Tegra ClkLib: Added missing tClockOptimise definition to clk_teg.h | Colibri T20, Colibri T30, Apalis T30 | Buildsystem | CE6, WEC7, WEC2013 |
Description: tClockOptimise enum definition was missing, generating compiler error when including clk_teg.h |
WCL-642 | Fixed | CAN: Flexcan implementation returns bytes and not number of messages | Apalis iMX6, Colibri iMX6 | CAN | WEC7, WEC2013 |
Description: Flexcan implementations of CAN_Read() and CAN_Write() have been changed to return number of messages |
WCL-641 | Fixed | Can Lib: Remove SingleThread feature for MCP2515 CAN | Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: Can Lib: SingleThread feature will not work for MCP2515 CAN as it anyway needs multiple threads inside the library. Workaround: Don't use single thread set to 1. |
WCL-639 | Fixed | UpdateLib for VFxx: Updating Eboot from Object Store Renders Module Unbootable. | Colibri VF50, Colibri VF61 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: Update Eboot.img from RAM fails |
WCL-638 | Fixed | I2C Lib Demo: i2cScan does not work on all platforms | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Scanning using a write with NULL size 0 does not work on all module families. |
WCL-636 | Fixed | UpdateLib is not working on the IMX7D | Colibri iMX7 | Toradex Feature | WEC7, WEC2013 |
Description: The Update Library fails on calling Upd_Init(NULL)) with an exception on IMX7D modules under WEC2013. |
WCL-635 | Fixed | Update lib: Invalid registry file generated on imx6 | Apalis iMX6, Colibri iMX6 | WinCE Feature | WEC7, WEC2013 |
Description: The exported registry file for i.mx6 is not valid and re-importing it restores the default registry instead. |
WCL-634 | Fixed | RpMsgLib: Rpmsg_Write Parameter Not Defined as Constant | Colibri iMX7, Colibri VF61 | CPU | WEC7, WEC2013 |
Description: Data to send by Rpmag_Write() is defined as void*, but should be const void* |
WCL-626 | Fixed | IMX6, IMX7, Vybrid: CAN library does not return errors in the correct way | Apalis iMX6, Colibri iMX6 | CAN | WEC7, WEC2013 |
Description: CAN_Read, CAN_Write, and CAN_WriteMultiple sometimes return the packet length (correct return code) even if there was an error performing the operation. |
WCL-625 | Fixed | Default I2c pins are not defined for Apalis iMX6 | Apalis iMX6 | I2C | WEC7, WEC2013 |
Description: Fixed by Added default pins assignments Workaround: Configure ioScl and ioSda through I2c_SetConfigInt. Refer more documentation at Toradex_CE_Libraries.chm |
WCL-624 | Fixed | Config parser context corruption occurs in WEC2013 | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T30, Apalis T30 | WinCE Feature | WEC2013 |
Description: When library APIs are running in a multithreaded environment that would cause a config parser context corruption error. |
WCL-621 | Fixed | CanLib WEC2013: Data Abort after Can_Init | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | WEC2013 |
Description: After calling Can_Init on the Can Library random data aborts have been seen. This has been fixed. |
WCL-617 | Fixed | Vybrid: CAN1 and CAN2 SODDIMM pinout documentation wrong | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: The pins documented for CAN1 and CAN2 swapped. CAN1 has pins
RX:Pin 63, TX: Pin 55 and
CAN2 has
RX: Pin 196, TX Pin 194. |
WCL-616 | New Feature | Added VS2015 Project Files and property sheets files | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Buildsystem | WEC2013 |
Description: LibDemos now also have all needed files to be opened by VS2015 |
WCL-615 | Fixed | On-module ADC is not accessible on iMX6 | Apalis iMX6, Colibri iMX6 | Analog Inputs | CE6, WEC7, WEC2013 |
Description: Calling ADC_Init fails on Apalis and Colibri iMX6 |
WCL-612 | Fixed | Updatelib: error updating config block on imx6 | Apalis iMX6, Colibri iMX6 | WinCE Feature | WEC7, WEC2013 |
Description: This has been fixed |
WCL-536 | New Feature | RpMsgLib: Support FreeRTOS and RpMsgLib on Colibri iMX7 | Colibri iMX7 | CPU | WEC7, WEC2013 |
Description: Adjust FreeRTOS to run on the iMX7's M4 core. Add support for the iMX7 in the RpMsgLib. |
WCL-529 | Fixed | .NET Wrapper: Wrong PInvoke definition of xxx_GetConfigString() | Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: When using our libraries from .NET, calls to the functions xxx_GetConfigString() fail, due a wrong .NET wrapper definition of the function's 2nd parameter. |
WCL-503 | Fixed | Gpio_GetConfigInt always returns 0 | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | GPIO | WEC7, WEC2013 |
Description: Gpio_GetConfigInt returns 0 as value for any parameter passed as input. |
WCL-488 | New Feature | Add DVFS and clocking funtions to IMX6 Clock library | Apalis iMX6, Colibri iMX6 | Power Management | WEC7, WEC2013 |
Description: The iMX6 clocking library supports APIs to set minimum and maximum CPU frequency. Those will work if DVFS is enabled in the image (supported from v1.3b4) |
WCL-485 | Fixed | SPI Modes on iMX6 not set correctly | Colibri iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: The idle state of the SCLK signal is implemented as '0' instead of '1' for SPI MODE 3. Workaround: Make sure that the SPICS signal is routed to the SPI slave device. As long as this chip select is active, the SCLK/MOSI signals behave as expected for all SPI modes. |
WCL-471 | New Feature | SPI lib: Alllow setting any pin to be a CS on iMX6 products | Apalis iMX6, Colibri iMX6 | SPI | WEC7, WEC2013 |
Description: On IMX6 the SPI CS pins are implemented as GPIOs. Currently it is not possible to select any other pin as CS. |
WCL-433 | New Feature | PwmLib on Vybrid: Support for >10 channels | Colibri VF50, Colibri VF61 | PWM | CE6, WEC7, WEC2013 |
Description: All 18 PWMs can now be used on Vybrid |
WCL-431 | Fixed | I2C library byte order for 16 bit register address | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: There is now a Config Parameter "RegisterAddrLE" to set the endianness of I2C parameter "RegisterAddr" when "RegisterAddrSize" = 16
- Added CANLib for Tegra - Improved SPILib performance and fixed default pin mappings - Improved I2CLib - Improved CANLib performance |
WCL-851 | New Feature | Add CAN support for T20/30 modules using the new library API | Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: Add support for the T20/30 modules for the CAN library using the newer API approach. |
WCL-793 | Fixed | SPI_Init() Crashes If There Are Parameters Stored in the Registry | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: If SaveToRegistry flag is passed the parameters are actually stored in registry, but at next restart calling SPI_Init leads to a crash. |
WCL-702 | New Feature | I2cLib on VFxx: Second I2c Port Stops Working | Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: I2C Read/Write can fail on second i2c port (i2c2), and block the i2c2 port permanently. Workaround: Please make sure that the pullup resistors on SDA and SCL are strong enough. If required, add extra pullups. |
WCL-633 | Fixed | I2CLib for Tegra: Changed default library port mappings | Colibri T20, Colibri T30 | I2C | CE6, WEC7, WEC2013 |
Description: On Colibri T30 library port name "I2C3" was using pins 49,51 by default, changed to use Ext15, Ext16 to make it compatible to Colibri T20. We also added new mapping for Colibri T30 "I2C4" using pins 49,51
On Colibri T20 we swapped "I2C2" and "I2C3" default mappings for the same reason to make it more compatible with Colibri T30 |
WCL-632 | Fixed | CANLib: Removed "RtrFormat" config | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: “RtrFormat” was initially used to set remote or data frame option used for CAN_Write() calls. Since the remote or data option can now be set as a flag in CAN_Write it does not make sense to have this config anymore |
WCL-631 | Fixed | CANLib: Changed config name "FrameFormat" to "FilterFrameFormat" | Colibri iMX7, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: "FrameFormat" was initially used to set the frame format used for CAN_Write() calls. Since the frame format can now be set as a flag in CAN_Write it does not make sense to have this config anymore. Instead we introduced a "FilterFrameFormat" config to filter out (remove) extended (29bit) or standard (11bit) received frames. |
WCL-630 | Fixed | GPIOLib for iMX7: changed config name "hys" to "inMode" | Colibri iMX7 | GPIO | CE6, WEC7, WEC2013 |
Description: iMX7 was the only one using "hys" (hysteresis) instead of the common defined "inmode" ("normal"/"schmitt")
Changed to make it compatible with other SOCs |
WCL-629 | Fixed | iMX7 Gpio Library: SODIMM 36 & 38 are swapped | Colibri iMX7 | GPIO | WEC7, WEC2013 |
Description: SODIMM to GPIO mappings for SODIMM pins 36 & 38 are swapped |
WCL-546 | Fixed | ADCLib: Multiple instances are not working in a process in T30 | Colibri T30, Apalis T30 | Analog Inputs | WEC7, WEC2013 |
Description: ADCLib: Multiple instances are not working in a process in T30 |
WCL-544 | Fixed | Vybrid GpioLib: falling to run multiple instance in a process. | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: Vybrid Gpio Library falling to run multiple instances in a process. |
WCL-534 | New Feature | SpiLib on Vybrid: Add Support for Wordwidths other than 8 and 16 Bits | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: The SPI Library for Vybrid currently supports only word widths of 8 and 16bits.
We can add support for 4 to 16 and 32 bit word widths. |
WCL-533 | New Feature | i2cLib for Vybrid: Make the library thread-safe | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: Make the i2c library for Vybrid thread-safe |
WCL-531 | New Feature | GpioLib for Vybrid: Convert from Driver to Library | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: Implement GpioLib without underlying driver and make it thread-safe. |
WCL-530 | Fixed | CAN library does not handle 29-bits message IDs properly | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: If user wants to send frame with extended if he just needs to set CanMsgFlags_IDE inside canMsgFlags. |
WCL-526 | Fixed | Imx6 Clock Lib: Use clock driver functions instead of directly accessing CCM registers | Apalis iMX6, Colibri iMX6 | Kernel | CE6, WEC7, WEC2013 |
Description: Imx6 Clock Lib: Use clock driver functions instead of directly accessing CCM registers. |
WCL-525 | Fixed | Tegra I2c library: Failing to run multi instance for multiple process | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Tegra I2c library: Failing to run multi-instance for multiple processes. |
WCL-522 | Fixed | SpiLib on iMX6: Improve Performance of Imx6Spi_ReadWrite() | Colibri iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: Remove overhead code that is executed each time when sending/receiving SPI data. |
WCL-521 | Fixed | SpiLib on iMX7: Improve Performance of Imx7Spi_ReadWrite() | Colibri iMX7 | SPI | CE6, WEC7, WEC2013 |
WCL-507 | New Feature | IMX6 FlexCan: Turn CAN Driver Into a CAN Library, Which Does Not Require Any Driver | Apalis iMX6, Colibri iMX6 | CAN | CE6, WEC7, WEC2013 |
Description: Improve FlexCan performance on iMX6 |
WCL-479 | Fixed | Update Rpmsg lib to sync with FreeRTOS Updates. | Colibri VF50, Colibri VF61 | Kernel | CE6, WEC7, WEC2013 |
Description: Update Rpmsg lib to sync with FreeRTOS Updates. |
WCL-475 | Fixed | CAN library does not allow reception of both standard and extended frames at the same time on imx6, vybrid and imx7. | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Added a configuration parameter to enable receiving of all frames. Refer to documentation about usage. |
WCL-473 | Fixed | i2cLib for Tegra: Teg_I2cWrite() returns no error even if written bit was not ACKed by slave | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: TegI2c_Write() may return success (number of sent bytes) even if there was no slave replying with an ACKnowledge bit. |
WCL-469 | Fixed | Multiplexed MISO pins are set to output level 1 | Colibri T20, Colibri T30 | SPI | CE6, WEC7, WEC2013 |
Description: If you configure SPI MISO that has a multiplexed second GPIO on the same pin, the not used GPIO is set to direction out, level high. |
WCL-468 | Fixed | SPI pins are touched in SPI_Init | Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | SPI | CE6, WEC7, WEC2013 |
Description: On Vybrid and Tegra the SPI pins are already touched in the SPI_Init function also there should be no access to the on the hardware before SPI_Open. Move this to SPI_Open. |
WCL-466 | Fixed | Recovery from FlexCAN bus error state | Colibri iMX7, Colibri iMX6, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Implemented CAN RESET inside Can_Init, this will clear the CAN Error bit on CAN controller. If CAN error bit is set and you want to clear it then please call Can_Deinit and Can_Init functions. |
WCL-465 | Fixed | FlexCan_status returns wrongs bits to the caller | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: FlexCan_Status returns wrongs bits to application |
WCL-464 | Fixed | GpioLib: Setting slew rate parameter did not work properly | Colibri iMX7 | GPIO | WEC7, WEC2013 |
Description: Setting slew rate to fast set it to slow |
WCL-463 | Fixed | FlexCAN Deinit generat exception on WEC2013 | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | WEC2013 |
Description: FlexCAN Deinit generate exception on WEC2013 |
WCL-462 | Fixed | FreeRTOS 1.0.1 Updates is not working on VF61 1.2A HW Modules | Colibri VF61 | Kernel | CE6, WEC7, WEC2013 |
Description: FreeRTOS 1.0.1 Updates is not working on VF61 1.2A HW Modules |
WCL-460 | Fixed | Missing documentation on clk_imx6.h functions | Apalis iMX6 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: some function parameters of the clk_imx6 library are not documented properly |
WCL-458 | Fixed | MCP2515 Apalis: Add support for default config for CAN on apalis T30 | Colibri T30 | CAN | WEC7, WEC2013 |
Description: Add default configuration for CAN on Apalis T30. |
WCL-453 | Fixed | I2cLib for Apalis T30: Library ports "I2c2" and "I2c2" are not the instances on the default pins | Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: On Apalis T30 modules, the library port "I2C2" does not refer to the default pinout. Workaround: To use the module's default SPI pins, use a different port name, as documented in the library help file, section i2c_teg.h. |
WCL-452 | Fixed | SpiLib for Vybrid: Library Port "SPI1" is not the instance on the default pins | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: On Colibri VF50 and VF61 modules, the library ports "SPI1" do not refer to the default pinout. Workaround: To use the module's default SPI pins, use a different port name, as documented in the library help file, section spi_vyb.h. |
WCL-451 | Fixed | SpiLib for Tegra: Library Port "SPI1" is not the instance on the default pins | Colibri T20, Colibri T30 | SPI | CE6, WEC7, WEC2013 |
Description: On Tegra modules, the library ports "SPI1" and "SPI2" do not refer to the default pinout. Workaround: To use the module's default SPI pins, use a different port name, as documented in the library help file, section spi_teg.h. |
WCL-447 | Fixed | Add support for SODIMM 71 as PWM on Vybrid | Colibri VF50, Colibri VF61 | PWM | CE6, WEC7, WEC2013 |
Description: SODIMM pin 71 can not be used as PWM in the Library. |
WCL-446 | Fixed | Several Non-SODIMM gpio pins not able to control through Gpio library | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: Several Non-SODIMM gpio pins not able to control through Gpio library |
WCL-442 | Fixed | UpdateLib: config block backup or restore operations may return wrong error code on imx6 | Apalis iMX6, Colibri iMX6 | ConfigBlock | CE6, WEC7, WEC2013 |
Description: If the library fails to re-activate the user partition after reading/writing config block the operation may return a success code. Workaround: Issue has been fixed and the fix is going to be include in next release of the libs. |
WCL-441 | New Feature | Add Documentation about used SPI channels for CAN on Apalis T30 | Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: Document mapping of SPI to CAN channels for Apalis T30 |
WCL-437 | Fixed | CAN: CAN_Write function does not return correct length on i.MX6, Vybrid and i.MX7 | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: The function has a counter that starts at -1 (error) and adds the number of bytes sent for each packet, returning one byte less than the actual amount sent.
If you send a zero length packet, the return value is still -1, meaning error. |
WCL-435 | Fixed | Flexcan: RTR bit in packet does not work, in configuration works only as string | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: If user wants to send RTR frame if he just needs to set CanMsgFlags_RTR inside canMsgFlags.
WCL-429 | Fixed | I2CLib Tegra: Calling TegI2c_Close without TegI2c_Open causes Data Abort | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Calling TegI2c_Close without calling TegI2c_Open before we end up in a data abort. |
- Extend all libraries to support the Colibri iMX7 - MCP2515 support for iMX6 - WatchdogLib for Tegra - Various bugfixes and stability improvements |
WCL-874 | New Feature | SpiLib on T20/T30: Add support for T20/30 modules using the new library API | Colibri T20, Colibri T30, Apalis T30 | SPI | CE6, WEC7, WEC2013 |
Description: Add support for Colibri T20/T30 and Apalis T30 modules to the SPI library. |
WCL-856 | New Feature | iMX6 Interrupt Library: Events before the interrupt is initialized lead to an unwanted signalized event | Apalis iMX6, Colibri iMX6 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: On i.MX6 you may have an interrupt event reported immediately after entering wait even
if you call InterruptDone before starting the wait loop. |
WCL-855 | New Feature | SpiLib for VF50/VF61: Add Support for Non-Standard Chip Select Pins | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: On Colibri VF50 and VF61, only the default SPI Chip select pin was working. We added support for other chip select GPIOs. |
WCL-854 | New Feature | CAN Library: Add Support for the MCP2515 on iMX6 | Colibri iMX6 | CAN | CE6, WEC7, WEC2013 |
Description: Implement MCP2515 support in the CAN library for Colibri iMX6. |
WCL-839 | Fixed | I2CLib: Open / Close cycle fails on Tegra | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Calling TegI2c_Open() after TegI2c_Close() can freeze the system. |
WCL-838 | New Feature | Add SPI Lib for Colibri iMX7 | Colibri iMX7 | SPI | CE6, WEC7, WEC2013 |
Description: Add SPI Lib for Colibri iMX7 |
WCL-837 | New Feature | Add I2C Lib for Colibri iMX7 | Colibri iMX7 | I2C | CE6, WEC7, WEC2013 |
Description: Add I2C Lib for Colibri iMX7 |
WCL-836 | New Feature | Add CAN Lib for Colibri iMX7 | Colibri iMX7 | CAN | CE6, WEC7, WEC2013 |
Description: Add CAN Lib for Colibri iMX7 |
WCL-834 | New Feature | VF61 FlexCan: Turn CAN Driver Into a CAN Library, Which Does Not Require Any Driver | Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Improve FlexCan performance on VF50 and VF61 |
WCL-828 | New Feature | Add PWM Lib for Colibri iMX7 | Colibri iMX7 | PWM | CE6, WEC7, WEC2013 |
Description: Add PWM Lib for Colibri iMX7 |
WCL-827 | New Feature | Add ADC Lib for Colibri iMX7 | Colibri iMX7 | Analog Inputs | CE6, WEC7, WEC2013 |
Description: Add ADC Lib for Colibri iMX7 |
WCL-826 | Fixed | Kernelcallbacklib: Deinit fails | Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Kernel, WinCE Feature | WEC2013 |
Description: Deinit on some libraries fails under WEC 2013 |
WCL-825 | New Feature | Implement WatchdogLib for Tegra | Colibri T20, Colibri T30, Apalis T30 | Watchdog | CE6, WEC7, WEC2013 |
Description: Implement the Watchdog Library using the Hardware Watchdog feature of the Tegra modules. |
WCL-821 | Fixed | i2c library for Vybrid: Internal Function SetConfig() Does Not Flag All Error Conditions | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: Some error conditions are ignored and not reported back to the calling function. |
WCL-820 | New Feature | iMX6 Spilib: Additional Configuration Options | Apalis iMX6, Colibri iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: Add support for SPI configuration options "DmaEnable", "MasterSlave", "PackedMode", "CsPulse" and "WaitMethod" |
WCL-812 | New Feature | I2cLib on iMX6: Make Timeout Configurable | Apalis iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: Use a programmable timeout for i2c operations, instead of a hard-coded constant timeout. |
WCL-807 | Fixed | Calling Spi_SetConfigString on i.MX6 return an error and 'unsupported CPU type' message | Apalis iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: SPI library for i.mx6 does not support any string parameter so calls to Spi_SetConfigString are supposed to fail, but the generated error message is misleading. |
WCL-678 | New Feature | UpdateLib for VFxx | Colibri VF50, Colibri VF61 | Bootloader, ConfigBlock, Flash | CE6, WEC7, WEC2013 |
Description: Implement Update Library for Colibri VF50 and Colibri VF61. |
WCL-543 | Fixed | I2C pinout configuration does not work | Apalis iMX6, Colibri iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: On Colibri iMX6 and Apalis iMX6, it is not possible to configure a non-standard pinout for I2C ports. |
WCL-537 | New Feature | I2cLib on iMX7: Make Timeout Configurable | Colibri iMX7 | I2C | WEC7, WEC2013 |
WCL-520 | Fixed | GPIO Lib: Gpio_Open() returns FALSE, when Registry path is used. | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | GPIO | CE6, WEC7, WEC2013 |
Description: If a registry path is passed to Gpio_Init(), the following call to Gpio_Open() fails. |
WCL-518 | New Feature | SpiLib on iMX7: Support Unpacked Mode | Colibri iMX7 | SPI | CE6, WEC7, WEC2013 |
Description: Add Support for Unpacked data |
WCL-517 | New Feature | SpiLib on iMX6: Support Unpacked Mode | Colibri iMX6 | SPI | CE6, WEC7, WEC2013 |
WCL-515 | New Feature | SpiLib Tegra does not read set registry settings | Colibri T20, Colibri T30, Apalis T30 | SPI | CE6, WEC7, WEC2013 |
Description: Library does not read the already set default configurations from registry editor. |
WCL-512 | Fixed | I2cLib: Memory Leak in TegI2c_Init() / TegI2c_DeInit() | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Possible memory leak when calling TegI2c_Init() and TegI2c_Deinit() functions only. |
WCL-511 | New Feature | Use new naming and versioning convention for Toradex software packages | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: We changed the naming and versioning format slightly in order to have a common approach for Linux, WinCE, and other Toradex software packages.
Details about the versioning can be found here: https://developer.toradex.com/knowledge-base/toradex-software-versioning-convention |
WCL-509 | Fixed | ClkLib: multiple instances not supported due to global variable is used | Colibri T20, Colibri T30, Apalis T30 | Kernel | CE6, WEC7, WEC2013 |
Description: ClkLib: multiple instances not supported due to global variable is used |
WCL-506 | Fixed | On Colibri iMX7, SODIMM 152 to SODIMM 199 pins can't be configured through Gpio library | Colibri iMX7 | GPIO | CE6, WEC7, WEC2013 |
Description: SODIMM 178, 184, 186, 188, 190, 192, 194 and 196 pins can't be configured through Gpio library |
WCL-505 | New Feature | SpiLib on VF50/VF61: Support Packed Mode | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: Add Support for packed data |
WCL-502 | Fixed | IMX6 I2C library generates a crash when used in kernel mode | Apalis iMX6, Colibri iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: I2C library generates an exception when initialized in kernel mode |
WCL-500 | New Feature | CAN Library: Add Support for the MCP2515 on i.MX7 | Colibri iMX7 | CAN | CE6, WEC7, WEC2013 |
Description: CAN Library: Add Support for the MCP2515 on i.MX7 |
WCL-499 | New Feature | Add update library for iMX7 | Colibri iMX7 | Bootloader, ConfigBlock, Flash | CE6, WEC7, WEC2013 |
Description: Add support for iMX7 to update library |
WCL-498 | Fixed | PwmLib for Vybrid: Library Does Not Properly Configure Multiplexed Pin 59, 67 for PWMA and PWMD signal respectively | Colibri VF50, Colibri VF61 | PWM | CE6, WEC7, WEC2013 |
Description: For Colibri VF50 and VF61, the PWMA signal on SODIMM pin 59 shows a voltage offset of 1.7V. This is caused by a multiplexed CPU pin, which is also connected to the same SODIMM pin. The same thing is applicable to PWM_D(SODIMM pin 67) signal as well. Workaround: Configure CPU pin PTC7 ( GPIO(52) ) as GPIO, Input for PWMA signal.
Configure CPU pin PTC6 ( GPIO(51) ) as GPIO, Input for PWMD signal. |
WCL-495 | New Feature | Implement WatchdogLib for iMX7 | Colibri iMX7 | Watchdog | CE6, WEC7, WEC2013 |
Description: Implement the Watchdog Library using the Hardware Watchdog feature of the iMX7 modules.
WCL-493 | Fixed | xxx_GetConfigString() Does Not Respect Maximum Buffer Size | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: The GetConfigString() function available in various libraries copies the full result string into the result buffer, even if this is more than what is defined in the maxBytes parameter. Workaround: Make sure that the result buffer you pass to GetConfigString() is large enough. |
WCL-492 | Fixed | Gpio_GetConfigString() Does Not Respect Maximum Buffer Size | Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Apalis iMX8, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | GPIO | CE6, WEC7, WEC2013 |
Description: The function Gpio_GetConfigString() writes all available data to the output buffer, and does not limit the string length to the size given in the "maxMytes" parameter. |
WCL-490 | New Feature | Memory Leak in iMX6 I2C library | Apalis iMX6, Colibri iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: There is a constant rise in Kernel Memory consumption nk.exe when i2c_init() and i2c_deinit() is called multiple times after the boot. |
- CAN library for VFxx and iMX6 internal CAN controller - RpMsg protocol for communication to the Colibri VF61 M4 core - ADC support for Tegra - Bug fixes in various libraries |
WCL-873 | Fixed | Can_Read() Does Not Return Actual Number of Bytes Read | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: The FlexCAN implementation of the Read function is supposed to return the size of the received message, but it's not returning the right value. |
WCL-833 | Fixed | RpMsgLib: Initializing RpMsgLib With Empty RegistryPath Is Not Properly Supported | Colibri VF61 | Kernel | CE6, WEC7, WEC2013 |
Description: The library did only partially support calling RpMsg_Init() with an empty or NULL registryPath, Workaround: Ignore debug message and make sure you don't store any configuration settings non-volatile. |
WCL-832 | New Feature | Support for GPIOs on the Extension Connector of Colibri iMX6 | Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: Add support for pins on the Colibri iMX6 extension connector that may be used as GPIOs. |
WCL-831 | Fixed | Apalis iMX6 Pin 239 Can't Be Used as a GPIO | Apalis iMX6 | GPIO | WEC7, WEC2013 |
Description: GPIO130 must be configured to output,high to enable Apalis pin 239 as a GPIO. Workaround: Include code in your application to configure GPIO130. |
WCL-830 | Fixed | NUM_EXTENSION definition must be updated | Apalis iMX6, Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: Internal ticket |
WCL-829 | Fixed | Memory Leak in KernelCallback Library | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Repeated calling of xxx_Init() and xxx_Deinit() for various libraries (Gpio, I2C, etc.) was leaking some memory. |
WCL-819 | Fixed | GpioLib for Tegra: Setting AltFn Always Disables Tristate | Colibri T20, Colibri T30, Apalis T30 | GPIO | CE5, CE6, WEC7, WEC2013 |
Description: On T20 and T30 modules, changing the AltFn of a GPIO always disables the tristate setting for this GPIO or the whole pin group. Workaround: Verify that disabling tristate does not generate critical glitches on the affected GPIO or pin group. |
WCL-818 | New Feature | CanLib for Vybrid/iMX: Query Status Register | Colibri iMX7, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Query status register of the CAN driver. |
WCL-817 | Fixed | GpioLib for Tegra: TegGpio_Open() Returns False if no Registry Path is Given | Colibri T20, Colibri T30, Apalis T30 | GPIO | CE5, CE6, WEC7, WEC2013 |
Description: TegGpio_Open() returns False if no registry path is defined Workaround: Provide a valid registry path, even if you don't need it. |
WCL-816 | Fixed | SpiLib on Apalis iMX6: Wrong SPI Instances | Apalis iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: On Apalis SPI1,2,3 and 5 are available, library incorrectly mapped SPI4 on the SPI5 pins. |
WCL-815 | Fixed | i2cLib for Tegra: TegI2c_Read() Does Only Support 8-bit Register Address | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: I2c_Read() on Tegra does only support 8-bit register addresses. 16-bit and 0-bit addresses are not supported. |
WCL-814 | Fixed | i2cLib for Tegra: TegI2c_Write() Does Not Return Number of Bytes | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: On Tegra, I2c_Write() returns an error status, instead of the number of bytes written. |
WCL-813 | Fixed | CanLib for Vybrid/iMX: Overwrites Registry Setting | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: The registry path to the can.dll driver gets overwritten on a call to Can_Open() Workaround: If you need to use a custom can.dll file, place it in the folder \Flashdisk\System\ |
WCL-811 | New Feature | GpioLib for iMX7: Support GPIO1_IO00 to GPIO1_IO15 | Colibri iMX7 | GPIO | CE6, WEC7, WEC2013 |
Description: Support GPIO1_IO00 to GPOI1_IO15 on Colibri iMX7 |
WCL-810 | Fixed | I2cLib on Tegra: Add Support for Internal I2c Channel | Colibri T20, Colibri T30, Apalis T30 | I2C | CE5, CE6, WEC7, WEC2013 |
Description: Add support for the internal i2c channel |
WCL-803 | Fixed | GpioLib: Improved config string parsing | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | GPIO | CE6, WEC7, WEC2013 |
Description: Parsing of configuration strings could be instable when passing invalid strings. |
WCL-802 | New Feature | Some Libraries (e.g. GPIOLib) for Vybrid/iMX are not Thread Safe | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: GpioLib for Vybrid and iMX is not fully thread-safe. |
WCL-801 | New Feature | UpdateLib for iMX6: Add Support for Registry Export/import and SPL Bootloader | Apalis iMX6, Colibri iMX6 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Update lib now supports registry export/import and also flashing SPL and eboot in SPL format. Requires BSP version 1.2 and later versions. |
WCL-800 | New Feature | New Apalis iMX6D 512MB IT Module Is Not Recognized by Coproclib | Apalis iMX6 | Kernel | WEC7, WEC2013 |
Description: The library does not recognize this module. |
WCL-798 | Fixed | i.MX6 SPI operations send and return wrong data if they are not 32 bit aligned | Apalis iMX6, Colibri iMX6 | SPI | WEC7, WEC2013 |
Description: SPI on i.MX6 supports also 8 and 16 bits word lengths, but if the total length of the frame is not 32 bit aligned, the first 1,2 or 3 words are not in the correct order or contain invalid data.
Workaround: This is a driver issue,not an issue of the SPI library, but to work correctly on i.MX6 SPI library needs, at least, release 1.1 of the image. |
WCL-797 | Fixed | IntLib: Make IntLib Usable for Driver Development | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | Kernel | CE5, CE6, WEC7, WEC2013 |
Description: Make IntLib usable for driver development |
WCL-794 | Fixed | CAN MCP2515 Is Broken in library pack 1.8 on Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: CAN through MCP2515 (on carrier board) doesn't work in library package 1.8 for Colibri VF50 and VF61. |
WCL-790 | New Feature | Add ADCLib support for T20/30 modules using the new API | Colibri T20, Colibri T30, Apalis T30 | Analog Inputs | CE6, WEC7, WEC2013 |
Description: Add support for the T20/30 modules for the ADC library using the newer API approach. |
WCL-726 | New Feature | Support FreeRTOS and inter processor communication | Colibri iMX7, Colibri VF61 | Kernel | CE6, WEC7, WEC2013 |
Description: Support FreeRTOS on Colibri VF61 and provide a communication library which can be used form WinCE to transfer information between WinCE and FreeRTOS and vice-versa. |
- Added Gpio and Coproc support for iMX7 - Added Pwm support for Tegra - Added SPI and Watchdog support for iMX6 - Added Can-through-SPI (MCP2515) support for Vybrid Various bug fixes and improvements |
WCL-877 | New Feature | Add splash screen update through Update lib | Apalis iMX6, Colibri iMX6 | Update System | WEC7, WEC2013 |
Description: A splash screen in the tss format can be flashed using UPD_Restore and setting "splashscreen" as section and "raw" as format. |
WCL-876 | Fixed | FlexCAN CAN read doesn't return length of received CAN message | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: FlexCAN Library doesn't return the length of received CAN message. |
WCL-875 | New Feature | I.MX6: SO-DIMM pins 59 and 67 are connected to multiple GPIOs | Apalis iMX6, Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: For multiplexed Colibri pins SODIMM-59 and SODIMM-67, pulldowns are now disabled for the secondary GPIO, as soon as the pin is configured as GPIO. |
WCL-872 | New Feature | Add PWM support for T20/30 modules using the new library API | Colibri T20, Colibri T30, Apalis T30 | PWM | CE6, WEC7, WEC2013 |
Description: Add support for the T20/30 modules for the PWM library using the newer API approach. |
WCL-871 | New Feature | Add I2C support for T20/30 modules using the new library API | Colibri T20, Colibri T30, Apalis T30 | I2C | CE6, WEC7, WEC2013 |
Description: Add support for the T20/30 modules for the I2C library using the newer API approach. |
WCL-868 | New Feature | Vybrid Internal CAN: Improve Write Performance | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Improve CAN transmit performance by allowing multiple messages to be sent at once. |
WCL-865 | New Feature | Add GPIO support for T20/30 modules using the new library API | Colibri T20, Colibri T30, Apalis T30 | GPIO | CE6, WEC7, WEC2013 |
Description: Add support for the T20/30 modules for the GPIO library using the newer API approach. |
WCL-862 | Fixed | MCP2515 CAN Lib: Optimize Performance | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | CAN | CE6, WEC7, WEC2013 |
Description: Introduced configuration parameter "SingleThread" which is 0 by default. By setting it to 1, the performance of the library can be significantly improved. |
WCL-859 | New Feature | Interrupt Library iMX6, Int_Deinit(), returns FALSE | Colibri iMX6, Colibri VF50, Colibri VF61 | Kernel | WEC7, WEC2013 |
Description: Typo error in the Deinit() function was there in the "return"/ |
WCL-853 | New Feature | SPI interface supports only 32 bit word lenght | Apalis iMX6, Colibri iMX6 | SPI | WEC7, WEC2013 |
Description: The Spi Library for i.MX6 only supports 32bit word width. Workaround: This is fixed in version 1.1B4, driver now supports 8-16 and 32 bits.
This will require an update of both the OS and the libraries. |
WCL-852 | New Feature | irqtrig=none does not behave as documented | Apalis iMX6, Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: The "none" value for irqtrig parameter has been removed since it was misleading, generating different behaviours on the different platforms and not actually disabling the interrupt as described. Irqtrig must be used to configure how the interrupt is detected (rising, falling edges, low or high level) and must be called before the interrupt is enabled. Int_InterruptInitialize and Int_InterruptDisable are the only functions that can be used to enable/disable interrupts. |
WCL-850 | Fixed | GPIO pull down is not correctly configured when using default values | Apalis iMX6, Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: When default values "up" or "down" are specified for the "pull" configuration parameter on i.mx6 the pin is not configured in the right way. Workaround: Using specific values "up22k", "up47k", "up100k" or "down100k".
WCL-848 | Fixed | PwmLib for iMX6: 2V High Level on PWMA, PWMD | Colibri iMX6 | PWM | CE6, WEC7, WEC2013 |
Description: On Colibri iMX6, PWMA and PWMD show reduced output voltages, because multiplexed GPIOs are driving against the PWM pins Workaround: Configure GPIO 48 and GPIO49 as (GPIO, input). This will be done automatically in library release V1.8. |
WCL-846 | Fixed | SpiLib for Vybrid: enum tSpiParam Does Not Match array paramList | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: Setting on any SpiLib config parameters could fail. Workaround: none. Will be fixed in V1.8 |
WCL-845 | Fixed | I2c Speed Is Not Preserved in a Multithreaded Environment | Colibri iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: When multiple threads configure the i2c bit rate for the same i2c bus, the last setting is used for all threads. Workaround: Fixed in Library revision V1.8 |
WCL-844 | Fixed | GpioLib: Read Back Registry Settings Does Not Work | Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30 | GPIO | CE5, CE6, WEC7, WEC2013 |
Description: Reading back registry settings automatically in Gpio_Open() does not properly work. Workaround: Use Gpio library functions to configure settings without the use of the registry, or
use updated library (V1.8 and higher) |
WCL-840 | New Feature | Implement SysInfo library | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Implement SysInfo library to request hardware and software versions of the system. |
WCL-806 | Fixed | IO string configuration options not documented | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | GPIO | CE6, WEC7, WEC2013 |
Description: Documentation only: Missing documentation for IO string options (i.e. Colibripin_*). |
WCL-805 | New Feature | Add GPIO lib for IMX7 | Colibri iMX7 | GPIO | WEC7, WEC2013 |
Description: Add support for GPIO library on IMX7 |
WCL-791 | New Feature | Add IMX7 support to CoProcLib | Colibri iMX7 | Kernel | WEC7, WEC2013 |
Description: Add support for CoProcLib on IMX7 |
WCL-767 | New Feature | SPILib for i.MX6 | Apalis iMX6, Colibri iMX6 | SPI | WEC7, WEC2013 |
Description: Library for the SPI interface on our iMX6 modules. Minimum BSP version 1.1beta4 is required. |
WCL-746 | New Feature | CAN Library: Add Support for the MCP2515 on Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Implement MCP2515 support in the CAN library for Colibri VF50 / VF61. |
WCL-718 | New Feature | Implement WatchdogLib for iMX6 | Apalis iMX6, Colibri iMX6 | Watchdog | CE6, WEC7, WEC2013 |
Description: Implement the Watchdog Library using the Hardware Watchdog feature of the iMX6 modules. |
WCL-717 | New Feature | Implement WatchdogLib for Vybrid | Colibri VF50, Colibri VF61 | Watchdog | CE6, WEC7, WEC2013 |
Description: Implement the Watchdog Library using the Hardware Watchdog feature of the Vybrid modules. |
WCL-713 | Fixed | PwmLib for iMX6: Wrong mapping | Apalis iMX6, Colibri iMX6 | PWM | WEC7, WEC2013 |
Description: The current default mapping "PWM Port Number" -> Colibri PWM Pin is incompatible. We will change this to the compatible assignment "PWM1"->PWM_A, ..., "PWM4"->PWM_D Workaround: Use SetConfigInt() to assign the correct GPIO to your "PWMx" port. |
WCL-712 | Fixed | CanLib: Functions Are Not Exported in TdxAllLibrariesDll.dll | Colibri iMX6, Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: CAN functions are not available in the DLL version of the libraries (TdxAllLibrariesDll.dll) Workaround: None - this will be fixed in library release V1.8.
- Added CAN library for VFxx and iMX6 internal CAN controller - Bug fixes in GpioLib and UpdateLib |
WCL-770 | Fixed | GpioLib for iMX6: Inconsistent Order Between ConfigParam enum and Matching String Array | Apalis iMX6, Colibri iMX6 | GPIO | CE6, WEC7, WEC2013 |
Description: GpioLib "speed" parameter configures wrong speed on i.MX6 |
WCL-766 | New Feature | CANLib for i.MX6 | Apalis iMX6 | CAN | WEC7, WEC2013 |
Description: Implement CAN library for Colibri and Apalis i.MX6, supporting the i.MX6 internal CAN controller |
WCL-758 | New Feature | CAN Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Implement CAN library for Colibri VF50 / VF61, supporting the VF50/VF60 internal CAN controller |
WCL-728 | New Feature | GpioLib: SetConfigString() Fails Silently On Invalid String Parameter. | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: SetConfigString() may fail silently on an invalid string parameter, and behave like a random valid string value was passed. Workaround: none - manually verify that you are not using unsupported configuration strings. |
WCL-719 | New Feature | MemMemLib: Map_AllocPhysMem() Throws an Exception on VF50 | Colibri iMX7, Colibri iMX6, Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Map_AllocPhysMem() Throws an Exception Workaround: Update the WinCE OS Image to at least the following version:
- VFxx: V1.3beta4
- iMX6: V1.0 |
WCL-715 | New Feature | GpioLib on iMX6: Cannot Configure SODIMM 67 to GPIO | Colibri iMX6 | GPIO | CE6, WEC7, WEC2013 |
Description: On Colibri iMX6: Gpio_ConfigureAsGpio() properly configures both related GPIOs for SODIMM 59, 67, 93 and 99. |
WCL-709 | Fixed | Updatelib Fails to Write OS Images on i.MX6 | Apalis iMX6, Colibri iMX6 | Bootloader | WEC7, WEC2013 |
Description: Sometimes the library does not write images correctly.
Fix requires V1.1 version of the bootloader (not yet released on 2016-05-18) |
WCL-691 | Fixed | Fix Implementation of VirtualSetAttributesCompat in MapMemLib | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Map_VirtualSetAttributes() does not work. Workaround: Update the WinCE OS Image to at least the following version:
- VFxx: V1.3beta4
- iMX6: V1.0 |
- Initial implementation of i.MX6 libraries - Various bug fixes |
WCL-788 | New Feature | Clocklib for iMX6 | Apalis iMX6, Colibri iMX6 | CPU | WEC7, WEC2013 |
Description: Implement a basic clock library for the i.MX6 to control simple clocking features. No advanced features are implemented though. |
WCL-786 | New Feature | Missing .NET Wrapper for SetPwm() Function | Colibri VF50, Colibri VF61 | PWM | CE6, WEC7, WEC2013 |
Description: SetPwm() Function is missing in the .NET wrapper file TdxAllLibraries.cs. Workaround: The source file TdxAllLibraries.cs is part of the library package. Therefore usesrs can add this function themselves. |
WCL-763 | New Feature | ADCLib for i.MX6 | Apalis iMX6, Colibri iMX6 | Analog Inputs | WEC7, WEC2013 |
Description: Extend the AdcLib to support the Colibri and Apalis iMX6 modules. |
WCL-762 | New Feature | PWMLib for i.MX6 | Apalis iMX6, Colibri iMX6 | PWM | WEC7, WEC2013 |
Description: Support PWM functionality |
WCL-725 | New Feature | I2C pins for I2C4 and I2C3 are not configured correctly inside the I2C library | Colibri iMX6 | I2C | WEC7, WEC2013 |
Description: Default pins (those configured by the driver) are non defined correctly for I2C3 (physical I2C1) on Colibri.
Pins for I2C are exchanged (SDA and SCL). |
WCL-724 | Fixed | iMX6 Colibri SODIMM 59 and 67 GPIO mapping are wrong. | Colibri iMX6 | GPIO, PWM | WEC7, WEC2013 |
Description: SODIMM 59 and 67 are wrongly mapped to GPIO 48 and 49 respectively. Correct is GPIO 41 and 1 respectively. These two pins can be used as PWM signals. |
WCL-722 | New Feature | iMX6 I2C2 pins are referred wrong configuration in the I2C library | Apalis iMX6, Colibri iMX6 | I2C | WEC7, WEC2013 |
Description: Colibri and Apalis iMX6: I2C2 default pins refer to wrong configuration. |
WCL-721 | Fixed | Gpio_GetConfigString not behaving correctly when NULL is passed as parameter name | Colibri iMX7, Apalis iMX6, Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: The documentation states that passing NULL as paramName2 parameter when calling Gpio_GetConfigString will return a string containing all the parameters.
This is currently not happening and the function crashes if the parameter is NULL. |
WCL-701 | Fixed | I2cLib on iMX6: "Timeout" Configuration Parameter Not Supported | Apalis iMX6, Colibri iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: Timeout parameter was incorrectly documented as supported on i.MX6. It's not supported and, at the moment, is not possible to set a timeout for I2C operations on i.MX6. |
WCL-700 | Fixed | I2cLib on iMX6: I2c_Write() Always Returns 0 | Apalis iMX6, Colibri iMX6 | I2C | CE6, WEC7, WEC2013 |
Description: I2C_Read and I2C_Write on i.MX6 returned -1 for an error or 0 in case of success, this has been fixed and now they return the number of bytes read/written as documented. |
WCL-683 | Fixed | .NET Wrappers For xxx_GetConfigInt() Functions Throw Exceptions | Apalis iMX6, Colibri VF50, Colibri VF61 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: .NET Wrappers For xxx_GetConfigInt() Functions Throw Exceptions Workaround: Use the .NET wrappers of the library package V1.6 or later. |
WCL-682 | Fixed | .NET Wrappers for Gpio_Normalize() and VybGpio_Normalize() Are Wrong | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: When calling Gpio_Normalize() or VybGpio_Normalize() from a .NET application, an exception is thrown. Workaround: Use the .NET wrapper of the library package V1.6 or later. |
WCL-679 | New Feature | UpdateLib for i.MX6 | Apalis iMX6 | Bootloader, ConfigBlock, Flash | CE6, WEC7, WEC2013 |
Description: Implement Update Library for Colibri and Apalis iMX6 modules. |
WCL-677 | New Feature | Read operation does not work on i.MX6 when register size is 0 | Apalis iMX6, Colibri iMX6 | I2C | WEC7, WEC2013 |
Description: When an application configures the "RegAddrSize" to 0 and tries to read data from I2C the libraries incorrectly generate a write request instead.
Workaround: For devices that can ignore a write request setting address size to 1 and doing a read can work.
WCL-674 | Fixed | SpiLib: Exception and Possible Freeze when calling VybSpi_Open() for SPI1..3 | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: VybSpi_Open() throws an exception and can cause a system freeze. Workaround: Ask Toradex support for a preliminary library release which has this problem fixed. |
- Fixes for several libraries in WEC2013 Debug configuration - General fix for GPIO registry configuration |
WCL-698 | Fixed | AdcLib: Exception Thrown When Intializing AdcLib | Colibri VF50, Colibri VF61 | Analog Inputs | WEC2013 |
Description: Adc_Init() generates an exception when run on a VFxx module under WEC2013.
The same code is working well under CE6 and WEC7. Workaround: Ask Toradex support for a preliminary version of the libraries including a fix for this issue. |
WCL-697 | Fixed | PwmLib: Exception Thrown When Intializing PwmLib | Colibri VF50, Colibri VF61 | PWM | WEC2013 |
Description: Pwm_Init() generates an exception when run on a VFxx module under WEC2013.
WCL-690 | Fixed | GpioLib: Gpio_Open() Fails, if a Registry Path is Given, But no IO Entries are Present | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: GpioLib: Gpio_Open() Fails, if a Registry Path is given, But no IO Entries are Present. Workaround: Add at least one IO Gpio configuration to the registry. |
WCL-688 | Fixed | Wrong Pin / GPIO Assignment for Apalis iMX6 | Apalis iMX6 | GPIO | CE6, WEC7, WEC2013 |
Description: For Apalis iMX6 V1.1 and later the following pin definitions are wrong in the GpioLib V1.4 (interchanged pairs):
112;118, 126;132, 134;136, 138;140 Workaround: This issue will be fixed in the V1.5 library release. Please contact support if you need a solution earlier. |
WCL-684 | Fixed | SpiLib: Exception Thrown When Intializing SpiLib | Colibri VF50, Colibri VF61 | SPI | WEC2013 |
Description: Spi_Init() generates an exception when run on a VFxx module under WEC2013.
- Use normalized naming convention for adc ports - Support multiple SPI chip select signals - Added support for i.MX6 in Coproc, MapMem and Gpio libraries |
WCL-789 | New Feature | SpiLib: Change the API Definition for Spi_Read() and Spi_Write() | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: The API for Spi_Read(), Spi_Write() and Spi_ReadWrite() has slightly changed: The type for the data buffers is now void* (it used to be DWORD*).
No change is required for the user application. |
WCL-785 | New Feature | CoprocLib: Extend Cop_GetSoc() to Differentiate Between iMX6 and Tegra | Apalis iMX6, Colibri iMX6, Colibri T20, Colibri T30, Apalis T30 | CPU | CE6, WEC7, WEC2013 |
Description: Implement support for the i.MX6 |
WCL-776 | New Feature | GPIO library for i.MX6 | Apalis iMX6, Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: Add support for GPIO configuration and state change also for i.MX6 |
WCL-775 | New Feature | MapMemLib for i.MX6 | Apalis iMX6, Colibri iMX6 | Kernel | WEC7, WEC2013 |
Description: Extend MapMem library to support the i.MX6 |
WCL-774 | New Feature | CoProcLib for i.MX6 | Apalis iMX6, Colibri iMX6 | Kernel | WEC7, WEC2013 |
Description: Extend Coproc library to support the i.MX6 |
WCL-773 | New Feature | i2cLib: Change the API Definition for I2c_Read() and I2c_Write() | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: The API for I2c_Read() and I2c_Write() has slightly changed: The type for the data buffer is now void* (it used to be DWORD*).
WCL-769 | Fixed | GpioLib: Callback Function Uses Wrong Parameter List | Colibri iMX6, Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: The GPIO library does not properly handling the configuration parameters "pull=up" and "pull=down". Workaround: Use the more specific settings like "pull=up22k" |
WCL-768 | Fixed | SPI on Vybrid Supports Only a Single Chipselect | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: The API supports only "ioCs" as parameter and this prevents configuration of different chipselects. Workaround: No workaround is available |
WCL-730 | New Feature | Changed Indexing of ADC Driver | Colibri VF50, Colibri VF61 | Analog Inputs | CE6, WEC7, WEC2013 |
Description: We changed driver indexing to match all other Toradex devices. Some users may need to fix their applications.
Example: ADC0 is now changed to ADC1, and ADC1 is changed to ADC2
- Improve SPI features - Use new naming convention for the SDK - Use normalized naming convention for i2c ports |
WCL-784 | Fixed | GpioLib: The VybGpio_NormalizeIo Function() Does Not Take a HANDLE Parameter | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: A parameter (HANDLE hGpio) was added to the functions Gpio_NormalizeIo() and VybGpio_NormalizeIo().
The source code in the user application needs to be adjusted for this change! Workaround: none |
WCL-782 | Fixed | I2C Library: Demo Application Shows Wrong Usage of Configuration Parameters | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: The I2c_Demo.c in the library package V1.2 shows a wrong usage of configuration parameters. Workaround: Use the demo in the library package V1.3. Also refer to the updated documentation on restrictions for the i2c configuration parameters. |
WCL-781 | Fixed | I2C Library: Make Driver Name Identical to Port Name | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: The Driver Name used inside the library was changed from "I2C0...I2C3" to "I2C1...I2C4".
In the Vybrid OS Images V1.1betaX and older, an i2c driver for the default pins is loaded as "I2C0", which is used by the RtcSync Tool.
The library now uses "I2C1" to access the default pins. This leads to potential collisions between RtcSync (using "I2C0") and a user application (using "I2C1"). Workaround: Will be fixed in OS Image V1.1 (not yet in V1.1beta2) |
WCL-779 | New Feature | Change SDK to New Naming Convention | Colibri VF50, Colibri VF61 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: Change the SDK Names to the new Toradex Naming Convention:
"Colibri600 (ARMV4I)" to "Toradex_CE600 (ARMV4I)", and
"Toradex800 (ARMV7)" to "Toradex_CE800 (ARMV7)".
This is relevant for the demo applications, and for the folder name, where the binary libraries are stored.
This only affects the library demos. Visual Studio will refuse to open the project, if none of the two SDKs is installed. Workaround: Install the new SDKs (Recommended!), or revert the project settings to the old naming convention. This can be done using the following steps:
1. Open all .vcproj and .sln files of the demo applications in a text editor.
2. do a simple text search&replace "Toradex_CE600 (ARMV4I)" to "Colibri600 (ARMV4I)" and "Toradex_CE800 (ARMV7)" to "Toradex800 (ARMV7)".
3. Rename the folders under \libs\lib\ and \libs\dll\ in the same way. |
WCL-777 | New Feature | SpiLib: Support 4-16bits Word Width | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: Support SPI word widths of 4..16 bits on Colibri VF50 and Colibri VF61.
Currently only 8 and 16 bits are supported. |
- Added i2c library - Fixed some bugs - Currently the Colibri VF50 and VF61 are supported |
WCL-759 | Fixed | Fix Wrong Return Value in Case Of Error | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: I2c_Read() and I2c_Write() are returning 0 instead of -1 in case of an error. |
WCL-757 | New Feature | I2C Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: Implement I2C library for Colibri VF50 / VF61 |
WCL-742 | Fixed | Remove printf() statements From Libraries | Colibri VF50, Colibri VF61 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: Remove printf error messages. Output errors to the debug port instead. |
WCL-741 | New Feature | .NET Wrapper for Toradex CE Libraries | Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Create a .NET wrapper class to access the Toradex libraries.
The current implementation is a preliminary, untested version. |
WCL-740 | Fixed | IRQ to GPIO Translation Issue On Old Vybrid Images | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: GPIO to IRQ translation does not work on Vybrid images V1.1beta1 and later. Workaround: Use Library package V1.2 or later, and Vybrid Windows CE image V1.1beta1 or later. |
WCL-735 | Fixed | GpioLib: A call to CSPDDK.DLL function GPIOSetAF() returns FALSE for Gpio 5 (PTA12). | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: On Colibri VFxx modules V1.0x, SODIMM pin 102 was mapped to GPIO 93.
On Colibri VFxx modules V1.1x and later, pin 102 is mapped to GPIO 5.
The library requires an update to properly access pin 102 on new modules. The fix requires a Windows CE image V1.1beta2 or newer. Workaround: Use the GPIO number 5 instead of the SODIMM number 102 to access the pin. |
WCL-734 | Fixed | I2cLib: CreateFile() for I2C Controller Instance 1, 2, and 3 (of 0..4) fails | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: The i2c library only works for the i2c0 controller, but fails for i2c1 to i2c3. Workaround: Currently none |
- Added ADC Library Fixed some bugs - Currently the Colibri VF50 and VF61 are supported |
WCL-756 | New Feature | ADC Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | Analog Inputs | CE6, WEC7, WEC2013 |
Description: Implement ADC library for Colibri VF50 / VF61 |
WCL-744 | Fixed | PWM Lib Demo Error When Loading the Solution in VS | Colibri VF50, Colibri VF61 | PWM | CE6, WEC7, WEC2013 |
Description: Pwm_Demo shows an error when the solution is loaded into Visual Studio. Workaround: Remove pwmLib project from the solution. |
WCL-737 | Fixed | SpiLib: Pin Direction | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: The SPI library does not always configure the pin direction correctly. Workaround: Configure the pin direction using the Gpio Lib.
This issue will be fixed in Library Package V1.1 |
- Initial Release of the Toradex CE Libraries.These libraries feature a completely revised API. - Currently the Colibri VF50 and VF61 are supported. |
WCL-888 | New Feature | GPIO Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | GPIO | CE6, WEC7, WEC2013 |
Description: Initial implementation of the Gpio library for Colibri VF50 and Colibri VF61. |
WCL-887 | New Feature | MapMem Library Using New API | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Initial implementation of the MapMem library. |
WCL-886 | New Feature | SPI Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: Initial implementation of the SPI library for Colibri VF50 and Colibri VF61. |
WCL-885 | New Feature | Coproc Library Using New API | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Initial implementation of the Coproc library. |
WCL-884 | New Feature | Clock Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | Miscellaneous Peripherals | CE6, WEC7, WEC2013 |
Description: Initial implementation of the Clock library for Colibri VF50 and Colibri VF61. |
WCL-883 | New Feature | Interrupt Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Initial implementation of the Interrup library. |
WCL-882 | New Feature | Coproc Library Using New API | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | WinCE Feature | CE6, WEC7, WEC2013 |
WCL-881 | New Feature | PWM Library for Colibri VF50 and Colibri VF61 | Colibri VF50, Colibri VF61 | PWM | CE6, WEC7, WEC2013 |
Description: Initial implementation of the PWM library for Colibri VF50 and Colibri VF61. |
WCL-880 | New Feature | KernelCallback Library Using New API | Colibri VF50, Colibri VF61 | WinCE Feature | CE6, WEC7 |
Description: Initial implementation of the KernelCallback library. |
WCL-879 | New Feature | MapMem Library Using New API | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | WinCE Feature | CE6, WEC7, WEC2013 |
WCL-745 | New Feature | MapMem Library Using New API | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | WinCE Feature | CE6, WEC7, WEC2013 |
WCL-869 | Known Issue | SpiLib for iMX6: Wrong Chip Select | Apalis iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: When using SPI2, the library uses the SPI5 chip select. |
WCL-863 | Known Issue | VF61 FlexCan: Transmit Rate Limited to 1 Message/ms | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: The CAN library is currently not able to send more than one message per millisecond Workaround: Will be fixed in library release V1.9 |
WCL-861 | Known Issue | MCP2515 CAN Lib: Receive Buffer Overflow | Colibri VF50, Colibri VF61 | CAN | CE6, WEC7, WEC2013 |
Description: Receive Buffer Overflows can occur, especially if there are short messages with short idle time on the bus. Workaround: Configure the library for Single Thread usage. This does not completely remove the problem, but it will minimize it by optimizing the library performance. |
WCL-824 | Feature Request | Tegra: Write One wire sample or library | Colibri T20, Colibri T30, Apalis T30 | One-Wire | CE6, WEC7, WEC2013 |
Description: Add onewire library for Tegra. |
WCL-796 | Known Issue | Pin configurations are always returned as GPIOs, even if they were setup as Colibri/Apalis Pins | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | GPIO, I2C, PWM, SPI | CE6, WEC7, WEC2013 |
Description: xxx_GetConfigInt() may return gpios/pins in a different format than they were configured by calling xxx_SetConfigInt(). This needs to be considered when doing a comparison. Workaround: To compare two Gpios, make sure that both are in GPIO format. You can achieve this by calling Gpio_NormalizeIo(). |
WCL-787 | Feature Request | Create ConfigBlock Library | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | ConfigBlock | CE6, WEC7, WEC2013 |
Description: This library allows access to the config block which contains data such as the serial number (MAC address), hardware version info, debug serial port settings, etc. Part of this library was available in the formerly called SysInfoLib available for PXA and Tegra modules. |
WCL-751 | Feature Request | Add Support to Register an Owner of a GPIO | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30, Colibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300 | GPIO | CE6, WEC7, WEC2013 |
Description: Provide functions to store a short string for each GPIO identifiying the owner library/driver/application.
The owner could be read back and for example be shown in the GpioConfig tool. |
WCL-704 | Known Issue | ADC pins on Vybrid cannot be used as GPIOs | Colibri VF50, Colibri VF61 | GPIO | WEC7, WEC2013 |
Description: ADC pins on Vybrid are controlled directly from the processor (on other modules they are connected to external controllers) and so they may be used as GPIOs, but the GPIO library does not support this because using them in that way can break compatibility with other modules. Workaround: Pins can be configured by mapping the IOMUX and GPIO controllers directly from the application, but it is strongly advised to not use them as outputs because this will make carrier board not compatible with most of the other modules. |
WCL-676 | Known Issue | SpiLib: VybSpi_ReadWrite() Hangs on Invalid Input Data | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: VybSpi_ReadWrite() hangs if transmit buffer values are out-of-range. Workaround: Make sure that each value in the transmit buffer is not larger than what the SPI word width can represent. |
WCL-675 | Known Issue | SpiLib: VybSpi_Read() Function Hangs in Some Error Cases | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: VybSpi_Read() function hangs in particular error cases. Workaround: Use VybSpi_ReadWrite() instead. Provide a dummy transmit buffer to this function, containing all 0xff. |
WCL-628 | Known Issue | SpiLib on Vybrid: VybSpiReadWrite with txBuffer=0 or rxBuffer=0 Does Not Work Correctly | Colibri VF50, Colibri VF61 | SPI | CE6, WEC7, WEC2013 |
Description: Spi_Read() fails on Vybrid Workaround: Use Spi_ReadWrite() instead |
WCL-622 | Known Issue | SpiLib for Imx6/7: Imx6/7Spi_Read() and Imx6/7Spi_Write() Fail For Large Transfers | Colibri iMX7, Apalis iMX6, Colibri iMX6 | SPI | CE6, WEC7, WEC2013 |
Description: Imx6Spi_Read() and Imx6Spi_Write() generate an Access Violation if numberOfFrames is larger than 256
The same applies to Imx7 Workaround: Use Imx6Spi_ReadWrite(), provide valid rxBuffer and txBuffer
The same applies to Imx7 |
WCL-607 | Known Issue | UpdateLib for Tegra: Saving the registry fails after updating image without splashscreen | Colibri T20 | Flash, Toradex Feature | CE6, WEC7, WEC2013 |
Description: When a Colibri T20 is updated in one step (through a .cfg file), and the .cfg file does not contain a splash screen, it is later not possible to save the registry. Workaround: Include the previous splash screen in the package of update source files. |
WCL-606 | Feature Request | UpdateLib for iMX7: Verify data after writing to flash | Colibri iMX7 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Verify each section after writing it to the flash |
WCL-601 | Known Issue | i2cLib for Tegra: System wide mutex is not handled properly | Colibri T20 | I2C | WEC7 |
Description: RtcSync and othe i2c applications are blocked between calls of I2c_Init() and I2c_Deinit(). |
WCL-571 | Known Issue | CAN write error if application quits without can_deinit() | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: If an application is closed (or crashes) before Can_Deinit() is called, it causes errors when sending CAN messages if the application gets started again w/o reset. The data still gets sent out. This happens with the internal CAN (FlexCAN) only and not with the external CAN controller. Workaround: Make sure you call Can_Deinit() before closing the application. |
WCL-557 | Known Issue | i2cLib for VFxx: Read with (RegisterAddrSize==0) transmits an empty write command | Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: When calling i2c_Read on a VFxx module, the device's slave address is always sent to the bus in "write" mode, even if there's no register address to transmit.
This reduces performance unnecessarily, and even might be invalid for some i2c devices. |
WCL-551 | Known Issue | UpdateLib for VFxx: Backup / Restore filesystem does not work for multiple filesystem partitions | Colibri VF50, Colibri VF61 | Toradex Feature | CE6, WEC7, WEC2013 |
Description: UpdateLib cannot backup / restore multiple filesystem partitions Workaround: use file copy |
WCL-535 | Feature Request | Support SPI Slave Mode for all Modules | Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | SPI | CE6, WEC7, WEC2013 |
Description: Support SPI Slave Mode |
WCL-532 | Feature Request | GpioLib for iMX6 and iMX7: Make it thread-safe | Colibri iMX7, Colibri iMX6 | GPIO | CE6, WEC7, WEC2013 |
Description: Make GpioLib for iMX6 and iMX7 thread-safe |
WCL-528 | Feature Request | SPI DMA support for iMX6 | Apalis iMX6, Colibri iMX6 | DMA, SPI | CE6, WEC7, WEC2013 |
Description: Support DMA mode for SPI on Apalis iMX6 and Colibri iMX6 |
WCL-524 | Feature Request | Remove asserts when driver is already loaded in libraries using drivers (e.g. I2C, SPI) | Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61 | I2C | CE6, WEC7, WEC2013 |
Description: Remove the asserts and use DEBUGMSG |
WCL-519 | Feature Request | Support for external bus | Colibri iMX6 | External Memory Bus | CE6, WEC7, WEC2013 |
Description: We don't plan to add special support for this. Workaround: It's possible to map the controller using the MapMemLib and then directly access the registers. |
WCL-487 | Known Issue | Implement 0 timeout configurable option for CAN library. | Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30 | CAN | CE6, WEC7, WEC2013 |
Description: Implement 0 timeout configurable option for CAN library. Workaround: Use separate receive thread so a potential wait doesn't block the rest of the execution. |
WCL-467 | Known Issue | SpiLib on Vybrid: Byte Order Reversed | Colibri VF50, Colibri VF61 | SPI | WEC2013 |
Description: When doing SPI transfers using multiple chip selects, the byte order of the data can get mixed up. |
WCL-454 | Known Issue | SpiLib for Tegra: Configuring a library port to use pins from a non-default hardware SPI instance is not possible | Colibri T20, Colibri T30, Apalis T30 | SPI | CE6, WEC7, WEC2013 |
Description: The assignment of library port name (used in Spi_Init) to the actual hardware SPI instance is fixed and cannot be changed. Workaround: Select the appropriate library port name matching your SPI pins, as documented in the library help file. |
WCL-668 | Feature Request | GpioLib: Make it Thread-Safe for iMX6 and iMX7 | Colibri iMX7, Apalis iMX6, Colibri iMX6 | GPIO | WEC7, WEC2013 |
Description: Add Thread-Safety to the GpioLib for iMX6 and iMX7 |
WCL-587 | Known Issue | RpmsgDemo comes with .bin firmware, instead of .elf | Colibri iMX7, Colibri VF61 | Miscellaneous Peripherals | CE6, WEC7, WEC2013 |
Description: The Rpmsg Demo in Libary V2.3 and older are shipped with a M4 firmware in .bin format instead of .elf format Workaround: Build the .elf file from source code, or download the .elf from https://www.toradex.com/community/questions/38633/ |
WCL-580 | Known Issue | SysinfoLib: Querying the BuildDate may report an old date on iMX6 modules | Colibri iMX6 | WinCE Feature | CE6, WEC7, WEC2013 |
Description: Sys_GetConfigString("BuildDate") may return an outdated Build Date Workaround: Check the file date of \Windows\initdb.ini |
