Toradex Easy Installer Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex Easy Installer. The tickets are split in two major states:
  • Submitted (open): new features and bug fixes for Toradex Easy Installer versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
We will update this table continuously in order to always provide the latest state of our development plan.
Clear Filter
Issue #StatusSubjectModuleSubsystemSeveritySubmitted for Mainline
5.7.1
Upcoming Toradex Easy Installer 5.7 Maintenance Release 1
TEI-1036Known IssueTezi crashes without display adapterVerdin iMX8M MiniLowNo
Description: Tezi 5.7.0 is crashing on 0068 SOM if no display adapter is connected on DSI
Workaround: Connect a display adapter
5.7.0 (Release date: 2022-06-30)
Upcoming Toradex Easy Installer Q2 2022 Quarterly Release.
TEI-1018Feature RequestImplement config block generation for assembly version #idVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6ConfigBlockLowNo
Description: Support for PID8 naming scheme when assembly version >25 (config block generation)
TEI-1017Feature RequestImplement parsing of assembly version > 25Verdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6ConfigBlockLowNo
Description: Support for PID8 naming scheme when assembly version >25 (parsing)
TEI-1016Known Issuetezictl image-install does not show Installation startedVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6LowNo
Description: Issues with `tezictl` when no images are available on the current feed
TEI-1006Feature RequestUse text "I Accept" instead of "I Agree"Verdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6LowNo
Description: Change EULA dialog acceptance button label to "I Accept"
5.6.0 (Release date: 2022-03-31)
Upcoming Toradex Easy Installer Q1 2022 Quarterly Release.
TEI-992Known IssueColibri iMX7D 1GB (eMMC) V.1.1B Detection May Not WorkColibri iMX7LowNo
Description: Detection of the Colibri iMX7D 1GB eMMC (0039) V.1.1B is not working correctly, because of that the wrong device tree is selected and Tezi is not able to read the config block.
TEI-986Feature Requesttezictl: add status command and timeoutNot applicableLowNo
Description: Improve tezictl timeout handling ans status reporting
TEI-979Known IssueConfig block writing with TEZI and varying boot partition sizesVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6, Apalis TK1LowNo
Description: Replacement of eMMC chips with different manufacturers can sometimes change some parameters like the boot partition size. When using Toradex Easy Installer to write configuration blocks (raw images) it is not possible to select a negative offset to count from the end of the partition, making image.json files incompatible between old and new eMMC chips.
Workaround: Use a wrapup.sh script to calculate the size of the boot partition and write the configuration block there. Tezi 5.6.0 will introduce a new offset parameter for this use case.
TEI-968Feature RequestImprove the UX on grayed-out images that require a newer version of Easy InstallerVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6LowNo
Description: Improve message in case an image requires an updated version of Toradex Easy Installer
5.5.0 (Release date: 2022-01-03)
Upcoming Toradex Easy Installer Q4 2021 Quarterly Release.
TEI-964Known IssueAutoinstall Flag Causes Tezi to Go Into an Installation-LoopVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis iMX8LowNo
Description: Toradex Easy Installer is falling into a "installation-loop" if autoinstall in image.json is set to true. The Easy Installer is supposed to only auto-install newer Easy Installer versions.
TEI-963Known Issueu-boot-initial-env Not Written on NAND modulesColibri iMX7, Colibri iMX6ULLBootloaderLowNo
Description: Toradex Easy Installer does not write u-boot-initial-env on NAND modules, instead U-Boot starts with default environment after the installation.
TEI-919Known IssueAnalogue VGA Not Working Out-Of-The-BoxApalis iMX6Buildsystem, Graphics, VGALowNo
Description: All 3 display interfaces DVI-D aka HDMI, parallel RGB as well as VGA should be brought up concurrently just like the Toradex Easy Installer 1.8 used to do. But currently, only the former two are brought up while analogue VGA requires manual intervention.
Workaround: To bring up analogue VGA as well you may manually add the following device tree overlay to the overlay.txt file:
apalis-imx6_vga_overlay.dtbo
5.4.0 (Release date: 2021-09-30)
Toradex Easy Installer Q3 2021 Quarterly Release. Learn more on https://www.toradex.com/news/540-release-of-toradex-easy-installer-for-imx-and-tk1-system-on-modules
TEI-949Feature RequestEasy Installed is failed to start on module with missing config blockApalis iMX8BootloaderLowNo
Description: Toradex Easy Installer fails to start if configuration block is missing
TEI-921Feature RequestAdd support for Colibri iMX6ULL 1GBColibri iMX6ULLToradex FeatureLowNo
Description: Add support for the new eMMC and 1GB RAM variant of Colibri iMX6ULL to the same colibri-imx6ull Easy Installer machine.
TEI-889Feature RequestSupport Second Ethernet InterfaceVerdin iMX8M PlusEthernetLowNo
Description: Support the second Ethernet interface of Verdin iMX8M Plus, with the PHY located on the carrier board. It is exposed through the connector X35, for Ethernet_2, from the Verdin Development Board.
5.3.0 (Release date: 2021-07-08)
Toradex Easy Installer Q2 2021 Quarterly Release. Learn more on https://www.toradex.com/news/530-release-of-toradex-easy-installer-for-imx-and-tk1-system-on-modules
TEI-791Feature RequestPrevent Toradex Easy Installer From Being Booted by BSP U-BootVerdin iMX8M Plus, Verdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8BootloaderLowNo
Description: An already installed BSP U-Boot should not be able to boot an Easy Installer image that is plugged into e.g. an SD-Card slot.
Workaround: TBD
TEI-790Feature RequestScale the Progress Window to the Screen WidthVerdin iMX8M Plus, Verdin iMX8M MiniUpdate SystemLowNo
Description: Correctly scale the progress window to the screen width
TEI-778Known IssueAutoInstall the EasyInstaller doesn't Automatically RebootVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8LowNo
Description: If one installs an image which requires a newer Toradex Easy Installer and one wants to use the autoinstall feature one can provide the newer installer alongside the image to be installed. Then the new installer is installed first followed by the installation of the image. The versions 2.0b4-2.0b7 however do not automatically reboot after installation of the newer Toradex Easy Installer but rather show the standard dialogue /Power off/Reboot/Return to menu/ instead
TEI-732Known IssueGet Rid of Spurious /etc/issueVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8Toradex FeatureLowNo
Description: Get rid of spurious /etc/issue as likely /etc/tezi-version should be used.
TEI-611Known IssueRestoring Completely Erased NAND Flash FailsColibri iMX7, Colibri iMX6ULLFlashLowNo
Description: Restoring a completely erased NAND flash fails using Toradex Easy Installer 2.x.
Workaround: Use Toradex Easy Installer 1.8 via recovery mode instead and erase the flash before installation.
TEI-181Known IssueMissing Security Label Support on Ext4Colibri iMX8X, Apalis iMX8FlashLowNo
Description: Security labels do not get written to the target file system if they are in place in a tar file.
TEI-173Known IssueResolution not correct when HDMI is not plugged-inApalis iMX8HDMILowNo
Description: Resolution of the Toradex Easy Installer HDMI is not plugged-in is not 640x480, this leads to Remote Desktop not showing the complete Toradex Easy Installer.
Workaround: Set 1024x768 as resolution manually in the Remote Desktop settings.
TEI-30Feature RequestAdd Feed to the List if OK Button is Pressed in Feeds DialogVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: When adding a custom feed, pressing OK should also add the entered feed to the feeds list.
2.0b7 (Release date: 2021-04-15)
TEI-773FixedToradex Easy Installer Hangs Installing Images With 'autoinstall' Enabled.LowNo
Description: The Toradex Easy Installer may hang trying to installing images with the 'autoinstall' property enabled in its image.json file.
TEI-708New FeatureToradex Easy Installer support for Verdin iMX8M Mini V1.1A/B with Verdin DSI to HDMI Adapter V1.1AVerdin iMX8M MiniHDMILowNo
Description: Add support for Verdin iMX8M Mini V1.1A/B with Verdin DSI to HDMI Adapter V1.1A.
TEI-676FixedDefault Display Interface Detection Not WorkingApalis iMX8XGraphics, RGBLowNo
Description: Unfortunately, the default display interface detection (required on Apalis iMX8 QuadXPlus 2GB ECC IT without DSI to HDMI chip being assembled) is not working as it seems to depend on some userspace intervention not happening during boot when executed from rc.local. This can be seen by the following message being printed during boot:
sh: bad number
On the aforementioned module, this leads to no UI being visible on parallel RGB.
Workaround: Either use VNC to remotely connect to the board or type the following in the serial debug console to get parallel RGB working
/ # killall tezi weston dbus-daemon
/ # rm /var/run/dbus/pid
/ # /etc/rc.local
2.0b6 (Release date: 2020-11-02)
TEI-649Feature RequestAncient Wrong Default U-Boot Environment Leaking Into Freshly Installed ImagesVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Apalis iMX8Toradex FeatureCriticalNo
Description: Unfortunately, ancient wrong default U-Boot environment compiled into the fw-utils aka fw_printenv/fw_setenv is leaking into freshly installed images of all i.MX 8 series based modules which may have various disastrous effects leading up to and including complete boot hangs.
TEI-632Feature RequestAdd Support for Apalis iMX8QXP 2GB WB IT V1.1BApalis iMX8XLowNo
Description: Add support for Apalis iMX8QXP 2GB WB IT V1.1B.
TEI-630Feature RequestAdd Support for Apalis iMX8QXP 2GB ECC IT V1.1BApalis iMX8XLowNo
Description: Add support for Apalis iMX8QXP 2GB ECC IT V1.1B.
TEI-626Known IssueAnalogue VGA Not WorkingApalis iMX6VGALowNo
Description: The analogue VGA display output is not working on Apalis iMX6.
Workaround: Until this feature is fixed in version 2.x please use stable version 1.8.
TEI-610Feature RequestAdd Support for Apalis iMX8QP 2GB WB V1.1BApalis iMX8LowNo
Description: Add support for Apalis iMX8QP 2GB WB V1.1B.
TEI-609Feature RequestAdd Support for Apalis iMX8QP 2GB V1.1BApalis iMX8LowNo
Description: Add support for Apalis iMX8QP 2GB V1.1B.
TEI-606Feature RequestAdd Support for Colibri iMX8QXP 2GB WB IT V1.0DColibri iMX8XLowNo
Description: Add support for Colibri iMX8QXP 2GB WB IT V1.0D.
TEI-605Feature RequestAdd Support for Colibri iMX8QXP 2GB IT V1.0DColibri iMX8XLowNo
Description: Add support for Colibri iMX8QXP 2GB IT V1.0D.
TEI-604Feature RequestAdd Support for Colibri iMX8DX 1GB WB V1.0DColibri iMX8XLowNo
Description: Add support for Colibri iMX8DX 1GB WB V1.0D.
TEI-603Feature RequestAdd Support for Colibri iMX8DX 1GB V1.0DColibri iMX8XLowNo
Description: Add support for Colibri iMX8DX 1GB V1.0D.
TEI-602Feature RequestAdd Support for Apalis iMX8QM 4GB IT V1.1BApalis iMX8LowNo
Description: Add support for Apalis iMX8QM 4GB IT V1.1B.
TEI-596Feature RequestAdd Support for Verdin iMX8M Mini Quad 2GB WB IT V1.1AVerdin iMX8M MiniLowNo
Description: Add support for Verdin iMX8M Mini Quad 2GB WB IT V1.1A.
TEI-593Feature RequestAdd Support for Verdin iMX8M Mini DualLite 1GB V1.1AVerdin iMX8M MiniLowNo
Description: Add support for Verdin iMX8M Mini DualLite 1GB V1.1A.
TEI-592Feature RequestAdd Support for Verdin iMX8M Mini DualLite 1GB WB IT V1.1AVerdin iMX8M MiniLowNo
Description: Add support for Verdin iMX8M Mini DualLite 1GB WB IT V1.1A.
TEI-572Feature RequestApalis iMX8QM 4GB WB RAM IssuesApalis iMX8RAM, SCFWLowNo
Description: Some modules may show various kinds of RAM issues (U-Boot failing to boot fit images due to bad hash, random squashfs errors, random kernel panics when BSP is flashed). Closer analysis identified NXP meanwhile having updated the RAM configuration/initialisation side of things. Updating to NXP's latest Register Programming Aid (RPA) v19 seems to fix those issues. Full validation & verification pending...
Workaround: Until this fix is officially released please use a recent nightly build. Note: You are looking for something like apalis-imx8/tezi/tezi-run/oedeploy/Apalis-iMX8_ToradexEasyInstaller_2.0b6-nightly-<date>.zip.
https://artifacts.toradex.com:443/artifactory/tezi-oe-prerelease-frankfurt/thud/nightly/
TEI-563Feature RequestAdd Support for Apalis iMX8X V1.1B and Colibri iMX8X V1.0C with i.MX8QXP C0 and PF8X00 C1Apalis iMX8X, Colibri iMX8XBootloader, CPU, Power ManagementLowNo
Description: Add Support for Apalis iMX8X V1.1B and Colibri iMX8X V1.0C with i.MX8QXP C0 and PF8X00 C1 requiring up-to-date SCFW and different SECO firmware.
TEI-558Known IssueRNDIS Networking Not Functional on Colibri iMX6ULLApalis iMX8X, Colibri iMX6ULLUSBLowNo
Description: RNDIS networking is not functional on Colibri iMX6ULL
TEI-538Feature RequestOptimise Feed Loading Based on Machine or Product IDVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureNo
Description: Optimise feed loading based on machine or product ID.
2.0b5 (Release date: 2020-05-19)
TEI-569FixedAuthentication Failed Trying to Connect Via VNCVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: While our VNC backend works quite stable now I regularly get an "Authentication failed" message the first time I try to connect to a just power-cycled module running Tezi. It does not seem to depend on whether Tezi got brought up in recovery or not, whether Ethernet or RNDIS is used and also waiting a few seconds before trying to connect does not seem to change anything. In average I get it about once every 6 power-cycles. I use Gnome's Remote Desktop Viewer aka Vinagre 3.22.0 on Fedora 30.
TEI-556New FeatureMake sure to Erase Environment when installing Toradex Easy InstallerVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8BootloaderLowNo
Description: By default the flash is not erased when installing a new image, but simply overwritten by the new image. The U-Boot environment however is typically not overwritten. This might influence the next image installation. Since installing the Toradex Easy Installer onto a device usually means that one would like to have the module behave like after a factory reset, installing the Toradex Easy Installer image should erase the Environment by default.
TEI-503New FeatureSupport custom ports for services announced via ZeroconfVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Add support to use a custom port for services announced via Zeroconf
TEI-501New FeatureSupport HTTPS Servers Announced Through ZeroconfVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Add support to announce servers with HTTPS trough Zeroconf.
TEI-500FixedURLs With Equal Signs are not Possible to Pass Through ZeroconfVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: URLs with equal signs are not possible to pass through Zeroconf.
TEI-496FixedVNC backend screenshare instance crashes at timesVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: VNC backend screenshare instance crashes at times.
Workaround: Unfortunately, once it crashed the Toradex Easy Installer needs to be rebooted to be able to try again.
TEI-493New FeatureAdd support for Apalis iMX8QXP 2GBApalis iMX8XBuildsystemLowNo
Description: Add support for Apalis iMX8QXP 2GB.
TEI-491FixedVNC: keyboard layout issueVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: If connecting to the Toradex Easy Installer with VNC the keyboard layout is messed up. E.g. when using a Swiss-German configuration one can't input characters like slash /. It messes up the keyboard input so hard that not even US input will work.
Workaround: As a workaround switch the host-side to US-English layout as follows: setxkbmap usvncviewer ...
TEI-487FixedBad output to Parallel RGB (both LCD panel / VGA)Colibri iMX6RGB, VGALowNo
Description: Tezi 2.0b4 with Colibri iMX6 shows a color-messy picture on Parallel RGB outputs.
TEI-472FixedSD Card not UsableColibri iMX6ULLSDIO/SD/MMCLowNo
Description: SD card is not usable.
Workaround: Load images via Ethernet/Internet or use a USB memory stick.
TEI-236New FeatureAdd Serial Command Line Support for Toradex Easy InstallerVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Support controlling Toradex Easy Installer from the serial console.
TEI-138New FeatureProvide HTTP APIVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Provide a HTTP API to control the Toradex Easy Installer. Please contact your Toradex sales representative for further details.
TEI-133FixedColibri iMX7S NAND Not Working in 2.0b4Colibri iMX7FlashLowNo
Description: NAND is not working on Colibri iMX7S in 2.0b4 release.
Workaround: Use stable Tezi release 1.8.
TEI-101New FeatureAnnounce VNC via zeroconfVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8EthernetLowNo
Description: Announce VNC capability via zeroconf.
TEI-100New FeatureUse host name with serial numberVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8EthernetLowNo
Description: Use host name with serial number to distinguish multiple modules on a network. This is useful when using mDNS or a DHCP infrastructure which supports client provided host names.
2.0b4 (Release date: 2019-12-31)
TEI-265New FeatureSupport Windows Host For RecoveryApalis iMX8X, Colibri iMX8X, Apalis iMX8BuildsystemLowNo
Description: Support Windows host for Toradex Easy Installer recovery.
Workaround: For the time being just use a Linux workstation optionally running in a VM of choice.
TEI-190New FeatureMove all Supported Modules to Mainline/Upstream Linux kernelColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30Kernel, Toradex FeatureLowNo
Description: Move all supported modules to mainline/upstream based toradex_5.4.y Linux kernel.
TEI-167New FeatureDisplay in multiple screens at the same timeVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8GraphicsLowNo
Description: Currently it is not possible to display the GUI in multiple screens at the same time.
TEI-142FixedVersion Comparison does not Support new Versioning SchemeVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: The Toradex Easy Installer compares version numbers when the "isinstaller" property is set to "true" to determine if there is a newer Toradex Easy Installer available. However, this version comparison code currently crashes when version numbers with different amount of segments are compared (e.g. 1.8 vs. 2.0.0). Furthermore the code does not support semantic Versioning, in particular the pre-release part of the version number is not taken into account.
Workaround: Since this only affects Toradex Easy Installer no work around required on customers end.
TEI-121New FeatureImplement VNC support for WestonVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Implement VNC support for Weston.
TEI-111FixedVNC not working when DVI/HDMI not plugged inApalis iMX8XToradex FeatureLowNo
Description: If DVI/HDMI is not plugged in Weston does not start. As a result, also VNC can't start.
TEI-108FixedApalis iMX8QM: Toreadex Easy Installer Does not Boot With PCIe DisabledApalis iMX8PCIeLowNo
Description: The Toradex Easy Installer crashes during boot if the regular off-module PCIe link can not be brought up. This is e.g. the case on the Apalis Evaluation Board if the PCIe switch is kept in reset (e.g. by removing jumper X3-4) or on Ixora if no mini-PCIe device is plugged in.
Workaround: On the Apalis Evaluation Board make sure the PCIe switch is not kept in reset (e.g. by placing jumper X3-4). On Ixora make sure a mini-PCIe device is plugged in. Alternatively, one may completely disable any PCIe functionality by specifying a tdxargs of initcall_blacklist=imx_pcie_init from within U-Boot:
setenv teziargs initcall_blacklist=imx_pcie_init
fastboot 0
TEI-104FixedCurrent uuu Version is Too LowVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis iMX8BuildsystemLowNo
Description: The current uuu version is too low in the Toradex Easy Install 2.0b3.
Workaround: You may manually update to a later uuu version downloadable from here:
https://github.com/NXPmicro/mfgtools/wiki#How-to-use-UUU-on-Windows
TEI-102FixedApalis iMX8 Kernel Crash on IxoraApalis iMX8KernelLowNo
Description: Kernel crashes when using Toradex Easy Installer 2.0b3 to recover an Apalis iMX8 module on a Ixora carrier board.
Workaround: Use previous Toradex Easy Installer or the Apalis Evaluation Carrier board.
2.0b3 (Release date: 2019-10-30)
TEI-226New FeatureSupport Server Discovery using Zeroconf TechnologiesColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Use zeroconf technology to let the Toradex Easy Installer find an appropriate image server (e.g. using DNS-SD, possibly also with mDNS support).
TEI-194FixedAdd --xattr-include=* to tarApalis iMX8X, Colibri iMX8X, Apalis iMX8FlashLowNo
Description: The CONFIG_EXT4_FS_SECURITY Linux kernel configuration was missing which prevented xattr from working properly.
TEI-171FixedDialogs can get behind main window and make it not responsiveColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8GraphicsLowNo
Description: When one clicks on the main window while a modal dialog is open, the dialog gets moved behind the main window. Since the dialog locks input to the parent window, the main window is now unresponsive and the Toradex Easy Installer is not usable.
Workaround: There is no workaround for this. Restart the Easy Installer and avoid clicking out of the window in focus.
TEI-168New FeatureAdd support for Apalis iMX8XApalis iMX8XKernelLowNo
Description: Add support for Apalis iMX8X.
TEI-160New FeatureAdd uuu recipeVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX8Toradex FeatureLowNo
Description: Currently the uuu utility used by tezi is pulled from a precompiled binary in tezi-run-metadata. A proper recipe for uuu is needed.
TEI-155FixedNo Icon Shown in Image ListApalis iMX8BuildsystemLowNo
Description: While the tezi.png icon is deployed with the package it is currently not shown in the image list as it is missing from image.json.
TEI-137FixedUn- and Re-Plugging the Same USB Memory Stick Keeps Re-Adding its Images to the ListVerdin iMX8M MiniToradex FeatureLowNo
Description: Un- and re-plugging the same USB memory stick keeps re-adding its images to the list.
TEI-119New FeatureProvisioning Container Images For TorizonCoreVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Apalis iMX6, Colibri iMX6, Apalis iMX8Toradex FeatureLowNo
Description: TEZI provisioning container images on TorizonCore
TEI-115FixedMissing SKU SupportColibri iMX8X, Apalis iMX8KernelLowNo
Description: The USB product IDs of the following SKUs are currently missing in the recovery scripts:
47: Apalis iMX8 QuadMax 4GB IT, 48: Apalis iMX8 QuadPlus 2GB Wi-Fi / BT, 32: Colibri iMX8 QuadXPlus 2GB IT, 33: Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth
TEI-114FixedSet hostname properly in certificateColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8Toradex FeatureLowNo
Description: The certificates CN does not match the modules hostname.
TEI-112New FeatureFix initial date timeColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis iMX8RTCLowNo
Description: Initial time of the Toradex Easy Installer without properly set RTC is rather random and might be in the distant past. This leads to RDP certificates with old validate dates.
TEI-110New FeatureAdd zstd supportVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61, Apalis TK1, Colibri T20, Colibri T30, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Add support for the zstd (Zstandard) data compression algorithm.
TEI-105New FeatureSet hostname/avahi announced hostname from serial numberApalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8EthernetLowNo
Description: Announce unique hostname via mDNS.
2.0b2 (Release date: 2019-07-17)
TEI-187FixedThe Ethernet Link May Constantly go Up/DownColibri iMX6ULLEthernetLowNo
Description: The Ethernet link may constantly go up/down with the following messages in dmesg:
[ 2.237374] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 2.739249] configfs-gadget gadget: high-speed config #1: RNDIS
[ 2.739922] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 11.385522] fec 20b4000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 11.385637] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.385379] fec 20b4000.ethernet eth0: Link is Down
[ 16.385482] fec 20b4000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 20.385077] fec 20b4000.ethernet eth0: Link is Down
Workaround: Re-loading the Toradex Easy Installer may recover the Ethernet link to a stable condition.
TEI-164New FeatureAdd support for Colibri iMX8XColibri iMX8XKernelLowNo
Description: Integrate support for Colibri iMX8X.
TEI-157FixedFlashing Image with 3.10 L4T Kernel Fails to BootApalis TK1FlashLowNo
Description: Images using the 3.10 L4T Kernel which get flashed with Tezi 2.0b1 do not boot. The kernel is not able to mount the file system and reports an error:
JBD2: Unrecognised features on journal
TEI-154New FeatureDisconnecting RDP Leaves Seat OpenColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Ethernet, GraphicsLowNo
Description: Disconnecting the RDP client leaves the mouse cursors on the display.
TEI-153New FeatureUsing RDP leaks memoryColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Ethernet, Miscellaneous Peripherals, RAMLowNo
Description: Using remote connection with RDP constantly leaks memory.
Workaround: Restart the Toradex Easy installer if needed.
TEI-152FixedAvoid using http caching when requesting images from feedsColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: When http caching is enabled, using the Refresh button to load newly added tezi images may not work, as the client is taking locally cached information.
Workaround: Reboot tezi to refresh caches
TEI-141New FeatureSupport uuu in containers without udevVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Apalis iMX8Toradex FeatureLowNo
Description: Support uuu without libudev support (e.g. for containerized environments).
TEI-15FixedReplace Tux with a Toradex Easy Installer icon during bootColibri iMX6ULLGraphics, RGBLowNo
Description: When launching Tezi the Linux penguin is quickly shown before the actual Tezu UI shows up. We will replace it with a Toradex Easy Installer icon.
2.0b1 (Release date: 2019-06-14)
TEI-365New FeatureAdd support for Apalis iMX8Apalis iMX8KernelLowNo
Description: Add support for iMX8 modules in the tezi images
TEI-259New FeatureUpdate to Qt5Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Colibri T30, Apalis T30GraphicsLowNo
Description: Updated to Qt5
TEI-169New FeatureUpdate OpenEmbedded Layers to ThudColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8BuildsystemLowNo
Description: Updated Openembedded layers to thud
TEI-159New FeaturePort Toradex Easy Installer to thudVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Ported Openembedded layers to thud
TEI-43FixedAdd support for IMX6ULL 512MB WB V1.1AColibri iMX6ULLKernelLowNo
Description: When trying to install a Toradex Easy Installer from a running Toradex Easy Installer in a iMX6ULL 512MB WiFi, the image will be displayed as incompatible.
Workaround: Download the Easy Installer image provided in our developer site. Extract the zip files and look for the image.json. In the supported_product_ids field add "0045" to the list. The image will now appear in the Easy Installer as installable.
TEI-34New FeatureAdd extra information in the prompt consoleColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Added link to Toradex Easy Installer article in the prompt welcome meassage.
TEI-31FixedAdd --xattr-include=* to tarColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8FlashLowNo
Description: When the Easy Installer untars the tarballs during installation, extended attributes do not get retrieved by tar if --xattrs-include=* is not passed as an argument together with --xattrs. This is in contradiction with the tar documentation, according to which --xattrs on its own suffices for tar to extract extended attributes.
TEI-26FixedDistro Boot Only Works From The First PartitionColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30BootloaderLowNo
Description: Turns out our current boot.scr script uses ${bootpart} rather than ${distro_bootpart} to reference the partition. Luckily, U-Boot just assumes the first partition if nothing is passed e.g. in a load command. That is why distro boot worked at all at least from the first partition.
Workaround: First, you have to make sure whatever partition you want to boot from is actually set to active boot in the partition table.
Then, change the boot script making sure you use ${distro_bootpart} rather than ${bootpart}. You may re-create the script from a text file as follows:
mkimage -T script -C none -n 'Distro boot script' -d boot.txt boot.scr
TEI-13New FeatureAllow to Control Behavior of mkfs.ext Utilities Through mke2fs.confColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8FlashLowNo
Description: Some file system settings are not available through command line of the mkfs utilities. Currently the settings file is stored in /etc/mke2fs.conf, which is in the read only part. Hence the current situation prevents to use a custom mke2fs.conf file.
Workaround: We have added the tune2fs utility into the tezi images, which can be invoked in the wrapup script to change the filesystem attributes after installation.
TEI-6FixedAfter Recovery From Erased NAND Flash the System Remains UnbootableColibri iMX7, Colibri iMX6ULLBootloaderLowNo
Description: If the complete NAND gets erased, e.g. by the U-Boot command 'nand erase.chip' the BCB data structure at the beginning of the NAND needs to be rewritten in order to boot from NAND. The Toradex Easy Installer does this as part of a missing Config Block recovery process.
Workaround: If you erase the NAND chip, do not write the Config Block in U-Boot. Recover with the Toradex Easy Installer which will interactively ask for the Config Block data and write the BCB.
1.9 (Release date: 2020-08-05)
Apalis TK1 maintenance release
TEI-613New FeatureToradex Easy Installer May Hang During BootApalis TK1Kernel, SATALowNo
Description: The Toradex Easy Installer version 1.8 may hang during boot with the following message shown last on its serial debug UART:
[ 0.456751] tegra-hdmi 54280000.hdmi: failed to get PLL regulator
Resp. without quiet:
[ 2.567691] tegra-ahci 70027000.sata: 70027000.sata supply target-12v not found, using dummy regulator
Workaround: This particular Linux kernel version seems to be susceptible to a AHCI SATA initialisation issue most likely related to clocking/PLL only happening on a few modules at lower temperatures. As AHCI SATA was never officially supported in the Toradex Easy Installer we just disabled it for now in the version 1.9 maintenance release. Alternatively, using any of the later Toradex Easy Installer versions like 2.0b6 also alleviates the issue.
1.8 (Release date: 2018-10-19)
TEI-77New FeatureAllow Executing an Error Script if Installer FailsColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30Toradex FeatureLowNo
Description: Execute an error script in case the installer fails installing the image.
TEI-22New FeatureLoad Toradex Easy Installer Configuration from SD card (used for kits)Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8SDIO/SD/MMCLowNo
Description: Start Toradex Easy Installer based on configurations defined on an SD card
TEI-18New FeatureAllow Disabling Default FeedsColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30Toradex FeatureLowNo
Description: Allow disabling default feeds by using a tezi_config.json on an external media. This can be used to prevent Toradex Easy Installer from showing any images from the Internet.
TEI-17New FeatureShow More Information for ImagesColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30Toradex FeatureLowNo
Description: Show detailed information of the selected image. The image.json description field will be shown more prominently as the image list appearance has been improved.
TEI-8New FeatureSupport Colibri iMX6ULL V1.1 SKUsColibri iMX6ULLKernelLowNo
Description: Add support for the Colibri iMX6ULL V1.1 versions. Older Toradex Easy Installers have problems with Ethernet on these SoMs.
1.7 (Release date: 2018-07-31)
TEI-83FixedApalis TK1 PCIe Gigabit Bring-up IssueApalis TK1Ethernet, PCIeLowNo
Description: Forward ported commit 7ad9771527d2 ("apalis-tk1: fix pcie reset for reliable gigabit ethernet operation") was never validated. Turns out it does not work and may lead to PCIe gigabit bring-up issues.
TEI-82FixedHigher Speed SD cards do not WorkApalis T30SDIO/SD/MMCLowNo
Description: Images on SD cards which do support faster modes than High Speed may not work.
Workaround: Use USB flash drive or SD cards which only support High Speed modes.
TEI-81FixedMouse/Keyboard Stops Responding for 10-15 SecondsApalis T30KernelLowNo
Description: After startup mouse and keyboard sometimes stops responding completely for 10-15 seconds. The system seems to recover on its own, and mouse/keyboard continue to work just fine.
TEI-80FixedInstalling an Image May Rarely Soft LockupApalis T30CPULowNo
Description: Image installation may rarely soft lockup. This has been observed with a rather slow internet connection.
Workaround: Just re-trying the installation even without power-cycling may work.
TEI-16FixedBoot hangs on 1.7 for Colibri iMX6Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6BootloaderLowNo
Description: Toradex Easy Installer 1.7 does not work for Colibri iMX6DL 512MB IT V1.0A.
1.6 (Release date: 2018-06-19)
TEI-291New FeatureSupport Apalis T30 ModulesApalis T30KernelLowNo
Description: Provide the Toradex Easy Installer for Apalis T30.
TEI-85New FeatureAdd support for new Coilbri iMX6ULL SKUsColibri iMX6ULLKernelLowNo
Description: Add support for Colibri iMX6ULL 512MB IT V1.0A.
TEI-78New FeatureeMMC Communication Errors when Running with HS400 at 100MHzColibri iMX7FlashLowNo
Description: The Kernel reports eMMC errors such as "mmcblk0: error -84 transferring data" during image installation. In some cases it might cause the installation process to fail.
1.5 (Release date: 2018-05-07)
TEI-247New FeatureImplement Boot Configuration Block Restore for Raw NAND DevicesColibri iMX7, Colibri iMX6ULLFlashLowNo
Description: When raw NAND devices are erased completely (e.g. using nand erase.chip in U-Boot), the boot configuration block has not been restored so far. With this release the Toradex Easy Installer will write a boot configuration block whenever the config block is missing (which is located in the same erase block.
TEI-96FixedUse Correct VGA Timings for parallel RGBApalis iMX6, Colibri iMX6RGB, VGALowNo
Description: The timing used on the Colibri iMX6 parallel RGB output (which is also converted to VGA on the Colibri Evalution Board) has a VGA resolution but is not the standard VGA timing. The same applies to the Apalis iMX6 parallel RGB as well as native VGA output.
Workaround: Use the Toradex Easy Installer with a different screen or a different graphical output such as HDMI/DVI-D or over network using VNC.
TEI-93FixedOffset in Sector does not Allow Minimal OffsetColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1FlashLowNo
Description: The field offset_in_sectors allows to specify a particular partition offset. By default, the minimal valid offset is used (for the first partition this is 8192 sectors/4MiB, for the subsequent ones depending on the size of the previous partition). Due to a "off-by-1" error the minimal offset leads to an error "Fixed partition offset too low".
Workaround: Since the minimal offset is the default anyway, do not specify "offset_in_sectors" if the minimal offset is required.
TEI-89FixedInstallation Process Blocks When Lots of Messages Are Writen to stderrColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1Toradex FeatureLowNo
Description: Installation Process might block on some tar files if GNU tar writes lots of warnings/errors to stderr. E.g. when the system clock is not correctly set (causing tar to print "time stamp .. in the future" warnings) or bsdtar has been used which uses header keywords not known by GNU tar (causing "Ignoring unknown extended header keyword" warnings).
Workaround: Make sure system time is correct either by using NTP (connect the module to the Internet) or manually using the date command (e.g. "date -s 2018-04-10"). Also, make sure the tarball has been packed using GNU tar to avoid header keyword warnings.
TEI-65FixedPrepare/Wrap-up Script Timeout is Ignored by the Toradex Easy InstallerColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1Toradex FeatureLowNo
Description: The Toradex Easy Installer executes prepare/wrap-up scripts with a timeout of 30s. However, if the scripts exceed the 30s, the installer ignores that and simply continues executing, assuming the script succeeded. Instead of using a timeout without a reasonable error handling wait forever until the script ended. Also print a warning after 30s.
1.4 (Release date: 2018-04-03)
This release supports image/configuration format 1 and 2! Using fw_setenv in wrap-up scripts is not supported anymore since the U-Boot environment utilities in Toradex Easy Installer no longer provide a default environment and default configuration file. Please migrate to use "u_boot_env" property in image.json and point to a U-Boot environment text file.
TEI-304New FeatureAllow Writing U-Boot Environment from a Text FileColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1Bootloader, FlashLowNo
Description: Allow writing a custom U-Boot environment from a text file provided alongside the with the image.
Workaround: Use fw_setenv in a wrap-up script.
TEI-302New FeatureSupport USB Device Mass Storage and RNDISApalis TK1USBLowNo
Description: Support USB device mass storage and RNDIS access in the Toradex Easy Installer for Apalis TK1.
Workaround: Revert to regular Ethernet, SD card or USB host support for now.
TEI-292New FeatureUse curl Instead of wget to Download ImagesColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1EthernetLowNo
Description: So far Toradex Easy Installer used wget to download images. The console utility curl provides better protocol support and more features.
TEI-290FixedErase Flash Not WorkingApalis TK1Flash, KernelLowNo
Description: Erase flash currently does not seem to work probably due to missing downstream Linux kernel discard functionality.
Workaround: Manually erase flash e.g. using U-Boot's 'emmc erase' command.
TEI-288FixedClipped Screen Due to VGA Resolution/Timing Not Being Fully VESA CompliantApalis iMX6, Colibri iMX6Graphics, Kernel, RGB, VGALowNo
Description: Our current VGA resolution timings are not fully VESA compliant which may lead to the screen getting clipped on the right side.
TEI-287FixedRe-enabling Mass Storage after Ejecting Mass Storage Devices FailsColibri iMX7, Apalis iMX6, Colibri iMX6FlashLowNo
Description: When using the USB mass storage emulation functionality and ejecting a device, re-enabling the USB mass storage emulation does not show the USB mass storage partitions again.
Workaround: Restart Toradex Easy Installer and enable the USB mass storage emulation again.
TEI-246New FeatureAdd Barcode Support for Config Block DialogColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1ConfigBlockLowNo
Description: Allow to use a USB attached bar code reader to fill fields when the config block recovery dialog is shown.
TEI-210New FeatureSupport GUID Partition Table (GPT)Apalis iMX6, Colibri iMX6, Apalis TK1FlashLowNo
Description: By default the Toradex Easy Installer does generate partition table in the DOS format. This adds support for GUID partition tables (GPT) by using the "table_type" property on block device level.
TEI-204New FeatureSupport Capacitive Touch Display 7" ParallelColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6Capacitive Touch, Graphics, RGBLowNo
Description: Add support for "Capacitive Touch Display 7" Parallel"
TEI-195FixedErase Flash (c) Not SupportedApalis TK1FlashLowNo
Description: The Toradex Easy Installer for Apalis TK1 currently does not support the 'Erase Flash (c)' button functionality.
Workaround: Either use the "mmc erase" U-Boot command or format your eMMC from Linux user space.
TEI-72FixedMake Sure That uid and gid do not get Changed by tarColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1FlashLowNo
Description: So far tar has been used without special setting on unpacking. It seems that the default behavior of tar translates textual user/group names to user/group ids according to the local user/group database. In Toradex Easy Installer case this means the user/group database of the temporary installer. This might lead to wrong user/group ids in the target rootfs. With 1.4 Tezi will use the --numeric-owner argument to make sure that all files/directories are created with user/group ownership by id as stored in the tar file.
Workaround: Add --numeric-id to the tar command when creating the rootfs archive. http://cgit.openembedded.org/openembedded-core/tree/meta/classes/image_types.bbclass#n128
TEI-71FixedToradex Easy Installer 1.3 does not Detect Ethernet ChangesColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1EthernetLowNo
Description: Toradex Easy Installer does not detect when Ethernet gets disconnected and does not recognize when a different Network gets connected after having a previous connection established.
TEI-69FixedRNDIS Sometimes not WorkingColibri iMX6ULLUSBLowNo
Description: RNDIS is only working sometimes.
Workaround: Retry by rebooting/recover the module again. Use Ethernet instead.
TEI-68New FeatureUpdate libusbgx Library to Latest Upstream VersionColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1USBLowNo
Description: Upstream libusbgx accepted our implementation of OS Descriptor support.
TEI-67New FeatureSupport ACL and xattrColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1FlashLowNo
Description: Make sure Toradex Easy Installer preserves/write extended attributes (xattrs) and ACL (access control lists) if they are present in a source tar file.
TEI-64FixedNo Link-Local IPv6 Adresses on Ethernet InterfaceColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1EthernetLowNo
Description: The ethernet interface (eth0) does not get a link-local IPv6 address assigned. This prevents IPv6 neighbor discovery protocol from working (SLAAC).
TEI-63FixedMissing Large File SupportColibri iMX7, Apalis iMX6, Colibri iMX6, Apalis TK1Flash, KernelLowNo
Description: The Toradex Easy Installer does not have the large file support distro feature (DISTRO_FEATURES += "largefile") enabled. This may lead to issues trying to flash file system archives which are bigger than 2GB (e.g. like the JetPack one).
TEI-57Fixedfw_setenv not Working on Colibri iMX7/iMX6ULLColibri iMX7, Colibri iMX6ULLBootloader, FlashLowNo
Description: fw_setenv cannot be used in a wrap-up script due to wrong configuration file.
TEI-56FixedMarketing Information Left Unpacked When using Locally Stored ImageColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1Toradex FeatureLowNo
Description: When using a locally stored image (e.g. on a SD-card or USB drive) Tezi unpacks marketing.tar and leaves it unpacked after installation. While Tezi keeps using the slides on next installation from a local media, the image cannot be uploaded to a server without creating a tar again.
Workaround: Recreate the marketing tar again if required.
1.3 (Release date: 2017-12-01)
TEI-283New FeatureAdd 3rp Party Feed for Images Provided by Toradex PartnersColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1Toradex FeatureLowNo
Description: Add an additional feed for 3rd party images.
TEI-240New FeatureSupport Apalis TK1 ModulesApalis TK1BuildsystemLowNo
Description: Provide the Toradex Easy Installer for Apalis TK1.
1.2 (Release date: 2017-10-06)
TEI-329New FeaturePrint Version on Serial OutputColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6UARTLowNo
Description: Print version of Toradex Easy Installer on the serial output
TEI-326FixedSupport 32-bit Linux DistributionsColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6BuildsystemLowNo
Description: Support 32-bit Linux distributions by providing imx_usb as a 32-bit binary.
TEI-281FixedWinCE Images with Records Containing empty Erase Blocks Lead to Error During FlashingColibri iMX7Toradex FeatureLowNo
Description: Flashing a WinCE image with empty pages between resources leads to a flashing error: "Short read, expected X bytes.".
TEI-280New FeatureImprove RAM settings for Colibri iMX7Colibri iMX7Bootloader, RAMLowNo
Description: Use optimized RAM timings as we found some issues on some modules and in our temperature testing.
TEI-279New FeatureProvide Mechanism to Manage External HTTP Servers (feeds)Colibri iMX7, Apalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: This adds a new dialog to manage external/additional http image lists directly within Toradex Easy Installer. Allow to disable/enable image lists and add secondary image lists for nightly builds/testing images.
TEI-245New FeatureConsider splitting meta-toradex-teziColibri iMX7, Apalis iMX6, Colibri iMX6BuildsystemLowNo
Description: +
TEI-218New FeatureSupport Colibri iMX7 Dual 1GB (eMMC) ModulesColibri iMX7KernelLowNo
Description: Support Colibri iMX7 Dual 1GB modules using eMMC flash.
TEI-217New FeatureSupport Colibri iMX6ULL ModulesColibri iMX6ULLKernelLowNo
Description: Support Colibri iMX6ULL modules using raw NAND flash.
TEI-214New FeatureUse unified Toradex Easy Installer for Colibri iMX7 modulesColibri iMX7KernelLowNo
Description: Unified Toradex Easy Installer for Colibri iMX7 modules
TEI-196FixedDo not Mux PWM Pins as OutputColibri iMX7, Apalis iMX6, Colibri iMX6PWMLowNo
Description: The PWM B, C and D pins are not used by the Toradex Easy Installer but still muxed as PWM and output by default (PWM A is used for display brightness). This might be problematic for designs which use the pins for a different purpose. Do not mux PWM B, C and D.
1.1 (Release date: 2017-09-06)
TEI-315New FeatureValidate JSON File Before Start Writing ImageColibri iMX7, Apalis iMX6, Colibri iMX6FlashLowNo
Description: The Toradex Easy Installer does not validate the JSON file before writing the image. Important parts could be missing. A JSON validation step helps to detect issues early and prevent failures during the flashing procedure.
TEI-311New FeatureAdd JSON Property to Erase Partitions/Devices Before FlashingColibri iMX7, Apalis iMX6, Colibri iMX6FlashLowNo
Description: Add per partition/block device erase option. This can be useful e.g. to get rid of the U-Boot environment by adding a "erase" property to the "mmcblk0boot0" block device node.
TEI-258FixedConfig Block Can Get Lost After Erasing eMMC If No Image Is FlashedApalis iMX6, Colibri iMX6ConfigBlockLowNo
Description: On devices with eMMC the Config Block gets temporarily stored in RAM during erase operation. When turning off during erasing or immediately after, the Config Block can get lost.
Workaround: Wait until erase completed and additional 50 seconds until write cache timeout passed or flash an image (which will force the write cache flush).
TEI-257FixedMissing Null Check on JSON ContentColibri iMX7, Apalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: Missing null check on JSON file content. If a JSON file contains any null fields, unexpected behaviour will result.
TEI-256FixedFlashing Over a Previously Installed Antmicro Android Image Might FailApalis iMX6FlashLowNo
Description: In case a module has an Antmicro provided Android image installed, flashing a new image might fail.
Workaround: Erase flash before installing the new image.
TEI-255FixedSPL Tries Booting From eMMC When Entered Recovery Mode via FallbackApalis iMX6, Colibri iMX6BootloaderLowNo
Description: A module enters the recovery mode implicitly e.g. when no bootloader has been found (typically after erasing flash). Using Toradex Easy Installer recovery in this case fails unexpectedly. The downloaded SPL tries to boot from eMMC.
Workaround: Enter recovery mode explicitly using the documented methods.
TEI-252FixedErase Flash BrokenColibri iMX7FlashLowNo
Description: Drücken diesen da 'Erase Flash (c)' machen alles kaputt!
TEI-251FixedFlashing Colibri iMX7S 256MB V1.1A or Colibri iMX7D 512MB V1.1A Renders Them UnbootableColibri iMX7BootloaderLowNo
Description: Unfortunately the Toradex Easy Installer currently does not take into account, that those early tapeout/stepping of the i.MX 7 SoC suffer a NAND flash issue requiring a software workaround. Starting with this version of Toradex Easy Installer it will prevent installation of any images on such modules.
TEI-229FixedU-Boot Continues Booting When Entered Recovery Mode via FallbackColibri iMX7BootloaderLowNo
Description: A module enters the recovery mode implicitly e.g. when no bootloader has been found (typically after erasing flash). Using Toradex Easy Installer recovery in this case fails unexpectedly. The downloaded U-Boot tries to boot from local storage and network.
TEI-225New FeatureAllow multiple image JSON files per directoryColibri iMX7, Apalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: All JSON files starting with "image" will now picked up on a local media. Images fetched via http can have multiple references to the same folder.
TEI-224FixedSome Volatile Directories are MissingColibri iMX7, Apalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: Some volatile directories are missing resulting in tools needing them failing. E.g. fw_printenv and fw_setenv which access and modify the U-Boot environment fail as follows: / # fw_printenv Error opening lock file /var/lock/fw_printenv.lock /var/lock is a symlink to /run/lock, but /run/lock does not exist.
Workaround: Create the missing directories with: / # /etc/init.d/populate-volatile.sh start
TEI-223FixedEnable Write Permission for Boot Partitions by DefaultApalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: eMMC boot partitions are read-only by default. The Toradex Easy Installer unlocks them only when actually flashing something. Utilities such as fw_setenv on the command line, or writing the boot partitions via USB mass storage emulation does not work.
Workaround: To use fw_setenv the boot partition can manually be unlocked using "echo 0 > /sys/block/mmcblk0boot0/force_ro".
TEI-222FixedAllow network image lists for unattended installation even without InternetColibri iMX7, Apalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: If there is no Internet connection, tezi.toradex.com can not be reached which creates an error and stops processing image lists downloaded over network connectivity.
Workaround: Use image on local media or make sure there is Internet connection available.
TEI-216FixedUSB Host port does not work on Colibri iMX7 Dual when the installer booted from flashColibri iMX7USBLowNo
Description: USB Host port does not work on Colibri iMX7 Dual when the Toradex Easy Installer has been booted from flash.
Workaround: Use Toradex Easy Installer via recovery mode or use USB OTG port.
TEI-215FixedMake sure legacy boot script can handle Toradex Easy Installer on raw NAND flashColibri iMX7Bootloader, FlashLowNo
Description: The legacy update scripts can only handle some UBI volume layout. Make sure the Toradex Easy Installer uses a layout which can be processed by the legacy update scripts.
Workaround: Erase UBI partition before using legacy update scripts (run erase.part ubi).
TEI-209FixedKeyboard not workingApalis iMX6, Colibri iMX6USBLowNo
Description: Most USB Keyboard do not work as well as hot plugging keyboards at runtime. This is particularly unfortunate when a config block restore is needed, since this operation can only be done using a keyboard.
Workaround: Use remote access via RNDIS/Ethernet and VNC to enter the config block information. Alternatively, use a Logitech wireless keyboard/touch mouse combination such as K400r which has been successfully tested.
TEI-207FixedObsolete Naming/VersioningColibri iMX7, Apalis iMX6, Colibri iMX6BuildsystemLowNo
Description: Currently the GUI still reads 'Toradex Easy Install v1.1' but we decided to leave that version aka v away for software artefacts.
TEI-206FixedFailed to Get Size of URLColibri iMX7Toradex FeatureLowNo
Description: Tezi 1.1pre gives the following error trying to install either Tezi 1.0 or LXDE-Image 2.7b3 via Internet: Failed to get size of URL.
1.0 (Release date: 2017-06-05)
TEI-308New FeatureShow a Restore User Interface If the Config Block Is MissingColibri iMX7, Apalis iMX6, Colibri iMX6ConfigBlockLowNo
Description: In case the Toradex Config Block isn't found on the module, a dialog is now shown which allows to restore the Config Block information by entering the information from the module sticker.
TEI-260New FeatureSupport Images in Deeper Levels of DirectoriesColibri iMX7, Apalis iMX6, Colibri iMX6Toradex FeatureLowNo
Description: So far only the first level of directories is scanned for images. With this change up to two levels of sub directories will be scanned.
Workaround: Make sure image description file (image.json) are nested not deeper than one level.
TEI-239New FeatureSupport Colibri iMX7 Solo 256MB and Dual 512MB ModulesColibri iMX7KernelLowNo
Description: Provide Toradex Easy Installer support for Colibri iMX7 Solo 256MB and Dual 512MB modules.
TEI-238New FeatureUse New Naming and Versioning Convention for Toradex Software PackagesApalis iMX6, Colibri iMX6BuildsystemLowNo
Description: We changed the naming and versioning format slightly in order to have a common approach for Linux, WinCE, and other Toradex software packages. Details about the versioning can be found here: https://developer.toradex.com/knowledge-base/toradex-software-versioning-convention
TEI-234New FeatureToradex Easy Installer Does not Use MAC Address From Toradex Config BlockApalis iMX6, Colibri iMX6Bootloader, ConfigBlockLowNo
Description: The U-Boot shipped with Toradex Easy Installer does not read the Config Block which leads to Linux not using the module individual MAC address with Toradex OUI.
TEI-200FixedRecovering Toradex Easy Installer Fails With USB IssuesApalis iMX6, Colibri iMX6USBLowNo
Description: Recovering Toradex Easy Installer fails with error messages on the serial console such as "EP0/in FAIL" (and similar).
Workaround: Some USB hosts might work better, also adding a USB hub between the host and target helps in some situations.
0.6beta (Release date: 2017-02-10)
TEI-331FixedRNDIS not Recognized by Win 10 Host by DefaultApalis iMX6, Colibri iMX6USBLowNo
Description: So far a generic Product ID and Vendor ID has been used, which some Windows 10 versions seem not to recognize. With this release, MS OS Descriptors are used for better compatibility across various Windows versions.
TEI-307New FeatureAdd Support for Colibri iMX6 ModulesColibri iMX6KernelLowNo
Description: Provide initial support for Toradex Easy Installer on Colibri iMX6 modules.
TEI-212FixedU-Boot Does not Detect Recovery Mode When Using bmode usbApalis iMX6, Colibri iMX6BootloaderLowNo
Description: When entering recovery mode via bmode usb command in a v2016.11 U-Boot, downloading Toradex Easy Installer via recovery mode failed.
TEI-198Fixedrecovery-linux.sh does not work with bmode usbApalis iMX6Bootloader, USBLowNo
Description: Using recovery-linux.sh after entering recovery mode via U-Boot bmode usb does not seem to work.
V0.5beta (Release date: 2017-01-23)
TEI-261New FeatureAdd Support for Apalis iMX6 ModulesApalis iMX6KernelLowNo
Description: Provide initial support for Toradex Easy Installer on Apalis iMX6 modules.
Not Planned
TEI-1028Known IssueDuplicate Images in FeedNot applicableLowNo
Description: Images in the Feed list may be shown more than once.
Workaround: Restart Easy Installer or delete the contents in /var/volatile/ from a console and press refresh.
TEI-1002Known IssueRandom MAC Address When Launched Via USB Recovery ModeVerdin iMX8M PlusLowNo
Description: Random MAC address leading to ever changing IP address when launched via USB recovery mode even though ConfigBlock is intact.
TEI-991Known IssueColibri iMX7D 1GB (eMMC) V1.1B Not Working With Version 1.8Colibri iMX7LowNo
Description: The Toradex Easy Installer 1.8, when flashed to the eMMC of a 0039 Colibri iMX7D 1GB (eMMC) V1.1B, is not working correctly as the ConfigBlock is not properly read.
Workaround: `setenv variant -emmc` in U-Boot before booting (it's not possible to save the variable change).
TEI-920Feature RequestNo ConfigBlock Plausibility Checks DoneVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8ConfigBlock, Toradex FeatureLowNo
Description: After flashing a Verdin iMX8M Plus ConfigBlock into an Apalis iMX6 the Toradex Easy Installer displays such without doing any further checks. It could easily detect this inconsistency and display the same dialog as if the ConfigBlock could not be read.
TEI-740Known IssueReports Bogus/Confusing Version Information (TDX_VER_ID)Verdin iMX8M Plus, Verdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Buildsystem, Toradex FeatureLowNo
Description: On the serial console the Toradex Easy Installer reports bogus/confusing version information: TDX_VER_ID="Colibri-iMX7_ToradexEasyInstaller_2.0b7-nightly-20201104" Instead of Colibri-iMX7_ToradexEasyInstaller_2.0b7-nightly-20210323 which is what I am running!
TEI-574Feature RequestAdd the commands poweroff and shutdownVerdin iMX8M Mini, Colibri iMX8X, Colibri iMX6ULL, Colibri iMX7, Colibri iMX6, Apalis iMX8, Apalis iMX6, Apalis TK1, Apalis T30LowNo
Description: Add the commands poweroff and shutdown
TEI-550Known IssueInstaller doesn't start automatically on Apalis TK1Apalis TK1Toradex FeatureLowNo
Description: Installer doesn't start automatically on Apalis TK1
TEI-484Feature RequestRandom MAC Address Leading to Random Ethernet IP AddressColibri iMX7No
Description: In recovery mode U-Boot cannot read the config block which leads to assign a random MAC address.
TEI-483Known IssueErase Flash (c) Does Not Preserve Raw NAND Flash Erase CountersColibri iMX7, Colibri iMX6ULLNo
Description: The "Erase Flash (c)" button on the Easy Installer does not preserve the NAND flash erase counters in /sys/class/ubi/ubi0/max_ec.
TEI-340Feature RequestSupport DNS-SD Service DiscoveryColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1EthernetLowNo
Description: Toradex Easy Installer should support using DNS-SD to discover an appropriate image server.
Workaround: Use server discovery using zeroconf technologies or use a custom local DNS Server which resolves tezi.toradex.com to a local image server.
TEI-312Feature RequestAdd support for optional files (not writing everything from scratch)Verdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Support optional flashing artifacts using a property in the image descriptor.
TEI-309Feature RequestAdd feature to hide/show unsupported imagesVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Add a check box which allows to also show images which are not compatible with the currently used hardware. By default the check-box is not selected and only compatible images are shown.
TEI-282Known IssueOnly 256MB of RAM Available When Installing BSP V2.6 Directly From Toradex Easy Installer U-Boot Due to Missing patch_ddr_size CommandColibri iMX6BootloaderLowNo
Description: During installation of BSP V2.6 directly from the Toradex Easy Installer U-Boot the following error message is shown but otherwise ignored by the installation procedure: Unknown command 'patch_ddr_size' - try 'help' As a consequence only 256MB of RAM will be available.
Workaround: Just manually execute the patch_ddr_size command once U-Boot from BSP V2.6 is installed. For existing production programming scenarios we do recommend to first separately update just U-Boot only (e.g. doing run setupdate; run update_uboot; reset) in order to make sure any further production programming scripting will proceed as before.
TEI-276Feature RequestProvide a mechanism to write at a specific offset from the end of the eMMC partitionColibri iMX7, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8FlashLowNo
Description: Provide a mechanism for raw files which allows to write at a specific offset from the end of the partition. This is useful to handle WinCE Config Block which is located at the end of the eMMC boot partition. Because eMMC boot partition sizes can vary the offset from the beginning depends on the exact product and product version.
Workaround: Use the wrapup.sh script to dd the configblock (or any other file) with a calculated offset from the end of the partition. For example: ... IMAGE_FOLDER=$4 ... OFFSET=$(($(cat /sys/block/mmcblk0boot0/size)-17)) echo "Writing configblock.bin to offset ${OFFSET}" dd if=${IMAGE_FOLDER}/configblock.bin of=/dev/mmcblk0boot0 count=16 seek=$OFFSET This also makes sure that the static config block does not get accidentally overwritten in case configblock.bin is too long. Note that this only works for images read from a local media, since only then configblock.bin is simply available in $IMAGE_FOLDER.
TEI-274Feature RequestSupport flashing WinCE splash screenColibri iMX7WinCE FeatureLowNo
Description: Support flashing WinCE splash screen.
TEI-253Known IssueConsider Including U-boot Environment PartitionColibri iMX7, Apalis iMX6, Colibri iMX6BootloaderLowNo
Description: The default U-boot shipped on modules with Tezi no longer includes a U-boot environment partition on the flash. This is an issue for customers who don’t replace the U-boot that comes on the module but want to set kernel arguments (e.g. video settings).
Workaround: Flash a U-boot which includes an environment partition & support for saveenv.
TEI-249Feature RequestMake ext3 Message More Dynamic From JSONApalis iMX6, Colibri iMX6FlashLowNo
Description: There is a hard-coded ext3 message somewhere in the Qt Tezi UI.
TEI-248Known IssueRecovery May Fail on Windows 7Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8BootloaderLowNo
Description: While launching the Toradex Easy Installer via recovery mode works on Windows 10 it may fail on Windows 7.
TEI-205Feature RequestSupport filtering by product revisionVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Currently images and files inside an image can be selected to be compatible with a product ID(s) using the "supported_product_ids" property. It should be also possible to filter by product revision.
TEI-199Known IssueToradex Easy Installer 0.5 Beta Does Not Run After InstallationApalis iMX6BootloaderLowNo
Description: Installing tezi 0.5 beta and doing a full power-cycle fails running it.
TEI-192Known IssueiMX7: recovery-windows.bat does not find USB device if it is connected behind a (USB3?) hubColibri iMX7USBLowNo
Description: Recovery mode might not work if there is a USB hub between the Colibri iMX7 and the PC.
Workaround: Remove the USB hub, connect the Colibri directly to the PC.
TEI-180Known IssueFeeds loading continuous despite image installation already started or even finishedColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Colibri iMX6, Apalis TK1, Apalis iMX8Toradex FeatureLowNo
Description: Loading the image list might generate errors even if the user started an image installation already (e.g. installing from a local device). This error message(s) do not disturb or interrupt the installation, but are confusing and unnecessary.
Workaround: Ignore "Error downloading image list" messages during installation.
TEI-179Feature RequestRefresh does not work sometimesColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8Toradex FeatureLowNo
Description: Refreshing images sometimes does not reload the image description files.
Workaround: Restart the Toradex Easy Installer. Manually clear the Qt Network disk cache using "rm -rf /tmp/data8/".
TEI-174Known IssueRDP doesn't work when network changedColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis T30, Apalis iMX8EthernetLowNo
Description: RDP does not work when network is changed and Toradex Easy Installer gets a new IP.
Workaround: Flash Toradex Easy Installer with correct network attached and do not change it on runtime.
TEI-170Known IssueUsing RDP the mouse cursor updates slowly or even gets stuckVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Especially on the lower end module the user interface over RDP feels slow. The mouse cursor and UI elements updates slowly and sometimes get even stuck.
TEI-156Known IssueFreeRDP May Fail Connecting Due to Enabled Server Heartbeat PDUApalis iMX8GraphicsLowNo
Description: FreeRDP commit 753b9c7ce9af ("Enable server heartbeat PDU by default.") changed heartbeat to be enabled by default which fails connecting to the Toradex Easy Installer running Weston RDP backend.
Workaround: Start FreeRDP with heartbeat being disabled e.g. as follows
xfreerdp -heartbeat -v:192.168.11.1
TEI-150Known IssueRestoring config block broken on raw NANDColibri iMX7, Colibri iMX6ULLConfigBlockLowNo
Description: Restoring config block on Toradex Easy Installer 2.0b1 on module with raw NAND is not functional.
TEI-129Feature RequestOlder Modules May Fail Booting Due to SoC Fusing IssueApalis iMX6, Colibri iMX6BootloaderLowNo
Description: Attempting to install a BSP 2.6 or later on an older Apalis iMX6 V1.0A, V1.1A, V1.1B (Apalis iMX6Q 2GB IT before 2017-05-30 only) or Colibri iMX6 V1.0A module for the first time may subsequently fail booting due to SoC fusing not being possible.
Workaround: Either use the legacy update procedure or an older Toradex Easy Installer version like stable 1.8.
TEI-126Feature RequestSupport fusing of modules using upstream KernelApalis iMX6, Colibri iMX6LowNo
Description: If you attempt to install BSP 2.6 or later on an older Apalis iMX6 V1.0A, V1.1A, V1.1B (Apalis iMX6Q 2GB IT before 2017-05-30 only) or Colibri iMX6 V1.0A module for the very first time it will not work, as prior to the Easy Installer version 2.0b4 we used to fuse them directly in that application. Later modules we since fuse in production.
Workaround: If you have one of the listed modules contact Toradex.
TEI-124Known IssueUn-Plugging HDMI Makes Other Display Flicker/Slow-Down and Gives Kernel BacktraceApalis T30Graphics, HDMI, RGBLowNo
Description: Un-plugging HDMI during runtime makes the other display flicker/slow-down and gives a kernel backtrace.
Workaround: Do not un-plug HDMI during runtime.
TEI-123Known IssueFlashing Images using Windows is not workingApalis TK1, Apalis T30Toradex FeatureLowNo
Description: Flashing images using Windows is not working for Apalis T30 and Apalis TK1.
TEI-113Known IssueExtend validity time of RDP certficatesColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Colibri iMX6, Apalis TK1, Apalis iMX8Toradex FeatureLowNo
Description: If the RTC does not provide a valid time and there is no internet connectivity, the Toradex Easy Installer sets the time to the build time. This time is used to generate the RDP certificate. When using the Toradex Easy Installer later than one year after the build time, the certificate will no longer be valid. The validity should be set to a reasonable long lifetime.
TEI-103Known IssueToradex Easy Installer does not Remove U-Boot Environment VariablesApalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: This is by design: Toradex Easy Installer merges the variable currently in the environment with the variables in the supplied text file. This is taken care of on the BSP side #58122.
Workaround: To delete a variable, add a variable with the same name but without a value (e.g. test=). Alternatively, erase the flash before flashing a new image to make sure only the variables in the supplied text file are set in the environment.
TEI-99Feature RequestRDP does not work with Windows RDP ClientVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Windows RDP client exits with an "internal error" when connecting to Tradex Easy Installer.
Workaround: Use Linux RDP client.
TEI-95Feature RequestUse a DHCP Option to Provide HTTP Server Address to the ImagesColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1EthernetLowNo
Description: If the Toradex Easy Installer is used with network only there is no way to provide a custom HTTP server to fetch the images from. Use a DHCP option to provide a HTTP image server.
TEI-92Known IssueDrop VNC in Favour of Using RDPColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8GraphicsLowNo
Description: With us moving to Qt 5, we dropped VNC support in favour of using RDP.
TEI-66Feature RequestMake Prepare/Wrap-Up Script Timeout ConfigureableColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1Toradex FeatureLowNo
Description: Normally prepare and wrap-up scripts execute only relatively short migration type tasks. Toradex Easy Installer therefor calls the scripts with a timeout of 30s. However, the scripts can be useful for various applications, such as flashing the complete image using a script itself. For this type of application a longer timeout is required. The timeout should be a configuration option in the JSON file.
TEI-61Known IssueUpdate lib: Invalid registry file generated on imx6Apalis iMX6, Colibri iMX6WinCE FeatureLowNo
Description: The exported registry file for i.mx6 is not valid and re-importing it restores the default registry instead.
TEI-59Known IssueToradex Easy Installer May Fail Bringing-Up USBColibri iMX7USBLowNo
Description: The Toradex Easy Installer 1.3 may fail bringing-up USB properly showing the following error on the serial debug console:
usb usb1-port1: cannot reset (err = -32)
Workaround: Just power-cycle and try again. Plugging the device in after boot may also help.
TEI-49Feature RequestPossibility to Change Parts of Bsp (U-Boot, Kernel or Devicetree) separatelyApalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: -
TEI-47Known IssueReduce the installed licenses disk usage by providing a manifestVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Currently a whole copy of the licenses is installed instead of a manifest only.
TEI-45Feature RequestSupport Colibri iMX8X ModulesColibri iMX8XKernelLowNo
Description: Port Toradex Easy Installer to Colibri iMX8X modules.
TEI-44Known IssueUnmounting media from the wrapup script is not workingVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8MultimediaLowNo
Description: When using the wrapup script to write into its storage medium (e.g. for log files, etc) and issuing a reboot thereafter, the medium should be first unmounted to avoid data corruption. A suggested way to unmount the medium wherefrom the wrapup script is executed is to create a delegate script in memory and exec it from the same wrapup. This approach doesn't seem to work, as umount will complain the resource is busy.
TEI-42Feature RequestConsider adding an autoreboot option in image.jsonVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Rebooting the system from the Easy Installer wrapup script is possible (by issuing the `reboot -f` command), but busybox will not unmount volumes on reboot, so such a reboot might lead to data corruption on an image from an SD card.
TEI-40Known IssueError Downloading Image List ShownApalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Error downloading image list. Intermittently, shown upon boot. Alternatively, if clicking on Feeds (f) too quick while it is still loading stuff this error is also always shown.
TEI-39Known IssueCPU Frequency Scaling Error During BootColibri iMX7CPU, Power ManagementLowNo
Description: The following is displayed in the serial debug console upon boot:
[ 17.672131] cpu cpu0: failed to scale vddarm up: -22
[ 17.677125] cpufreq: __target_index: Failed to change cpu frequency: -22
TEI-36Feature RequestAdd support for Wi-Fi built-in or dongleVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Wi-FiLowNo
Description: Having Wi-Fi support makes it easier for evaluation purposes.
Workaround: Duplicate
TEI-35Feature RequestSupport product number in addition to product idVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: The image.json should provide an option to filter by full product number (8 digit) in addition to product id only (4 digit).
TEI-20Known IssueUSB 3.0 Devices Plugged in at Boot Time Behind a USB Hub is not AccessibleColibri iMX7USBLowNo
Description: On the Colibri Evaluation Board V3, a USB 3.0 device plugged in at boot time is not accessible after boot. Furthermore, the device seems to influence the on-board USB hub in a way that any USB port 1-4 won't work anymore.
Workaround: Plug the USB 3.0 flash drive after startup or use a USB 2.0 flash drive.
TEI-19Known IssueUSB Ports do not Work SometimesApalis TK1USBLowNo
Description: USB ports at times do not work
Workaround: Power cycle the device
TEI-7Known IssueDetect Existance of Boot Configuration BlockColibri iMX7, Colibri iMX6ULLFlashLowNo
Description: Currently the existence of the Toradex Config Block is used to determine whether a valid BCB (boot configuration block) is present. Technically, those are two separate things. It is possible to erase the flash and only write the Troadex Config Block from U-Boot, in which case the Toradex Easy Installer will assume that there is a valid BCB. This sequence leads to a unbootable module.
TEI-5Known IssueAllow Toradex Easy Installer Automatic Installations if Run From RAMColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Colibri T30, Apalis T30, Apalis iMX8RAMLowNo
Description: Trying to automatically install an older or equal version of the Toradex Easy Installer from a running Toradex Easy Installer is not allowed. This is desired in most use cases (e.g. installing from an SD card), but it can become a problem in others, particularly when re-flashing the Toradex Easy Installer from a recovery image.
Workaround: Currently the workaround for this is setting `isinstaller: false` in the json config, but this may cause problems of infinite install loops.
TEI-2Feature RequestUse DHCP Option 12 to Communicate HostnameColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30EthernetLowNo
Description: Currently, the DHCP client used in Toradex Easy Installer does not provide a hostname. So even when using a DHCP server with DNS integration it will not be possible to ping the Toradex Easy Installer by hostname/FQDN.
Backlog
TEI-1020Known Issueu-boot-fw-utils default environment is wrongApalis iMX6, Apalis iMX8, Colibri iMX6, Colibri iMX6ULL, Colibri iMX7, Colibri iMX8X, Verdin iMX8M Mini, Verdin iMX8M PlusLowNo
Description: When the user provides an environment file as part of the image.json, and the environment partition is deleted, Tezi will install the default environment from BSP 5 and append the variables on the user provided environment file.
Workaround: You can delete unwanted variables as defined by the Toradex Easy Installer specification: Add the variable without any value in the file used by u_boot_env (ie. vidargs=)
TEI-774Feature RequestAdd Support For filesystem_type: swapVerdin iMX8M Plus, Verdin iMX8M Mini, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8LowNo
Description: Add support for filesystem_type: "swap", so that a swap partition can be setup during an Easy Installer installation.
TEI-725Feature RequestProgress Bar Not Working for Raw FilesLowNo
Description: Adding the "size" property to raw files, as described on Toradex Easy Installer: Configuration Files: Raw Files, does not make the progress bar display the installation progress.
TEI-710Feature RequestSupport Loading Toradex Easy Installer From USB Stick/SD Card Using DistrobootVerdin iMX8M Plus, Verdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Distroboot from USB Stick/SD Card may allow you to load Toradex Easy Installer into a Toradex SoM without the need of going through recovery mode, which involves exposing a USB OTG interface and using a computer.
While this seems easier, due to limitations on the SoC vendors BSP - such as the SCU firmware - it is not a maintainable feature and therefore not supported by Toradex.
Workaround: Keep in mind that Toradex Easy Installer is a production programming tool, not meant to be used as an update tool. If you need to update the full OS image for devices on the field and still insist on using it, make sure that your hardware design is aware of the requirements for entering recovery mode. Alternatively, consider adopting an OTA solution: for instance, if you are using Torizon, consider adopting Torizon OTA.
TEI-551Feature RequestSupport custom icon name for Toradex Easy Installer imagesVerdin iMX8M Mini, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Currently the Toradex Easy Installer image class on Yocto hardcodes the icon to "toradexlinux.png". A customer might want to use his own icon, named differently.
Workaround: In your Yocto layer, create a file named "recipes-bsp/tezi-metadata/tezi-metadata_%.bbappend" and add a function "do_deploy_append()" where you overwrite "toradexlinux.png".
TEI-490Known IssueAdd new Feed: pressing numbers selects/unselects servers (even in input field)Verdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Add new Feed: pressing numbers selects/unselects servers (even in input field).
TEI-289Feature RequestShow a Warning if an Image is Likely Too LargeColibri iMX7, Colibri iMX6ULLFlashLowNo
Description: Since UBIFS is compressed on-the-fly the Toradex Easy Installer cannot reliably estimate whether an image fits on internal NAND ahead of time. However, Toradex Easy Installer should make a rough estimate and print a warning if the UBIFS will likely not be able to fit the image.
TEI-278Feature RequestDo Not Mux Any Pins as Output Which is Not Essential for Toradex Easy InstallerVerdin iMX8M Mini, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis iMX8GPIOLowNo
Description: To allow using Toradex Easy Installer on carrier boards which use non Colibri/Apalis standard functionality the Toradex Easy Installer should make sure to not mux/use any non-essential pin.
TEI-250Feature RequestNo Way to Deploy Alternate Device Tree on NAND ModulesColibri iMX7Device TreeLowNo
Description: While we deploy all device tree blobs into the FAT partition of our eMMC modules currently in the NAND case we only deploy one single one. In the previous case of using our U-Boot update scripts the one chosen was dependent on the fdt_board environment variable. Now in the Tezi case there is no way to influence this yet.
TEI-235Feature RequestAdd Checksum for Files Written to FlashColibri iMX7, Apalis iMX6, Colibri iMX6FlashLowNo
Description: To validate integrity of the image a checksum for each file getting written to the flash should be stored in the image description file.
TEI-227Feature RequestSupport Resistive Touch ScreenColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Resistive TouchLowNo
Description: Resistive touch screens cannot be calibrated yet.
Workaround: Use a USB mouse to control the Toradex Easy Installer user interface.
TEI-145Feature RequestShow Easy Installer on Parallel RGB and DVI/HDMI SimultaneouslyColibri iMX8XRGBLowNo
Description: Due to a combination of hardware and software architecture issues it is currently not easily possible to clone the same output to HDMI and parallel RGB.
TEI-144Feature RequestUse kexec to Start Toradex Easy Installer From a Running Linux SystemVerdin iMX8M Mini, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8KernelLowNo
Description: Support running Toradex Easy Installer from within a running Linux system using kexec.
TEI-143Feature RequestMove to New Versioning SchemeVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Use the new Toradex versioning scheme.
TEI-139Feature RequestAnnounce HTTP API through AVAHIColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Announce the Toradex Easy Installer HTTP API on the local network using AVAHI.
TEI-132Feature RequestAdd support for Apalis iMX8X 1.1AApalis iMX8XKernelLowNo
Description: Add support for Apalis iMX8X 1.1A
TEI-131Known IssueVNC Cannot be Used after Disconnecting RNDIS while having a VNC Session RunningApalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: When disconnecting RNDIS while a VNC session is running, no other VNC session can be created anymore.
TEI-116Feature RequestSupport 10" LVDS DisplayApalis iMX6, Apalis TK1, Apalis iMX8LVDSLowNo
Description: Support Toradex Capacitive Touch Display 10.1"
TEI-109Feature RequestDo Not Store File Sizes in image.jsonColibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8Toradex FeatureLowNo
Description: Allow to estimate size of images correctly without specifying sizes in image.json.
TEI-107Feature RequestSupport LVDS Screen in Toradex Easy InstallerApalis iMX6Graphics, LVDSLowNo
Description: Support LVDS Screen in Toradex Easy Installer
TEI-106Known IssueToradex Easy Installer doesn't boot from USBApalis iMX6USBLowNo
Description: Toradex Easy Installer doesn't boot from USB.
TEI-79Feature RequestAvoid Downloading Unrelated image.json from ServerColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30Toradex FeatureLowNo
Description: Currently the Toradex Easy Installer downloads every image.json references in a image list just to check whether the image is compatible with the module at hand. This does not scale well as we add support for more and more modules. Introduce a image list format which states which modules a particular image is for.
TEI-46Feature RequestColibri iMX7 With WinCE Does Not Boot After Flashing an Image Using Toradex Easy InstallerColibri iMX7FlashLowNo
Description: Toradex Easy Installer sometimes can fail to update a NAND Flash Colibri iMX7. eMMC Colibri iMX7 are not affected.
Workaround: Use the flashimage command in Eboot, or the UpdateTool in Windows CE to program a new image.
TEI-33Known IssueFeed server not found through RNDISVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8USBLowNo
Description: When using RNDIS to download an image list from a custom server in a host, tezi silently fails.
TEI-28Known IssueToradex Easy Installer sometimes fails to install image from InternetVerdin iMX8M Mini, Apalis iMX8X, Colibri iMX8X, Colibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30, Apalis iMX8EthernetLowNo
Description: Installing from Internet sometimes gets stuck at the very beginning.
TEI-899Feature RequestAssess and Generalize Recovery Mode HandlingColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1BootloaderLowNo
Description: Assess and generalize recovery mode handling. Make sure upon recovery mode detection the default U-Boot environment is used rather than the one stored in flash to avoid any bad side-effects. Once U-Boot proper is running automatically start USB fastboot to allow for downloading further parts like e.g. the Toradex Easy Installer ITB.
Workaround: The downstream bring-up i.MX 8/8X/8MM U-Boot already behaves like that and maybe consulted for guidance.
