This is a database showing devices tested to work on Toradex's hardware. For more information, use the filters to select a device and click its name to head to its specific page.
Type | Interface | Features | Manufacturer | Device |
Antenna Cable | MHF4 to RP-SMA Outdoor | Cable length (200mm), IP67 waterproof | Chang Hong | Antenna Cable |
Antenna Cable | MHF4 to RP-SMA | Cable length (200mm) | Chang Hong | Antenna Cable |
Antenna Cable | MHF4 to RP-SMA | Cable length (100mm) | Chang Hong | Antenna Cable |
Antenna | Dipole | 2.4 GHz, 5 GHz, CE (EEA), FCC (USA), IC (Canada), SMA, TELEC (JAPAN), WPC (India) | Chang Hong | DA-2458-02 RP-SMA |
