Manufacture: | Sierra Wireless |
Device Type: | Cellular |
Interface: | PCIe |
Features: | GNSS: Yes GSM/GPRS/EDGE LTE UMTS/HSPA |
Hardware / Firmware Version | Module (Version) | Board (Version) | OS (OS / BSP Version) | Note | Test Date |
No results found. |
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / - | Any Module (Any Version) | Any Carrier Board (Any Version) | Yocto (Linux) (Any) | - |
Tip: Even though the form factor is mini PCIe, modems often only use the USB interface. It will work even if your SoM doesn't have a PCIe interface, as long as the USB signals from the mini PCIe connector are available. You must check the datasheet of the specific device for more details.
