Windows CE Library - System Information Library (SysInfoLib)
Description
This library provides access to configuration information.
Current Version
V1.4
Application Notes
SysInfoLib provides access to OS version, Image version, Boot Loader version, Board version, Board Serial Number, MAC Address and more.
Library API
Other Resources
Windows CE Libraries Overview
Get Serial Number
MAC Address
Revision History
DateRevChange Notes
11/03/2014V1.4fixed documentation of return values for SysInfoLibDeInit() and SaveUserData()
Make sure that return value TRUE is represented as 1 in functions GetBoardVersion(), GetMACAddress(), SetMACAddress() and GetBoardSerial()
23/09/2013V1.3.2Change default SDK to Colibri600
12/08/2013V1.3.1Fixed getSystemSpeeds() to output correct CPU Speed on Tegra processors
