Watchdog Software Library API
 This article describes the Watchdog software library API and provides a functional overview
Defines
#define WATCHDOG_VER_MAJ   1
 Major Library Version.
#define WATCHDOG_VER_MIN   0
 Library Subversion.
#define WATCHDOG_VER_BUILD   0
 Library Build.
Functions
void WatchdogGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL WatchdogInit ()
BOOL WatchdogDeinit ()
BOOL WatchdogRetrigger (DWORD Timeout_ms)
Detailed Description
WatchDog Support Library.
Author:
kia, $Author$
Version:
$Rev$
Date:
$Date$
Target Platforms:
Colibri PXA320, Windows CE 6.0
Caveats:
The watchdog does not work on PXA270 due to bug in the PXA270 CPU.
Define Documentation
Library Build.
Library Subversion.
Function Documentation
BOOL WatchdogDeinit( )
Deactivates watchdog This is not possible, therefore the function always returns FALSE
Return values:
TRUEsuccess
FALSEerror
void WatchdogGetLibVersion(DWORD * pVerMaj,
  DWORD * pVerMin,
  DWORD * pBuild
returns the version of this library
Parameters:
[out]pVerMajMain Version of this library
[out]pVerMinSubversion of this library
[out]pBuildBuild Number of this library
BOOL WatchdogInit( )
Activates the watchdog, and sets the Watchdog timer to the maximum timeout: 2^32 ticks / 3.125MHz = 1'374sec = 23min.
Return values:
TRUEsuccess
FALSEerror
BOOL WatchdogRetrigger(DWORD Timeout_ms)
Retriggers Watchdog
Parameters:
[in]Timeout_msA hardware reset will be done if the Watchdog is not retriggered within this time [ms]
valid range: 1...1'374'389
Return values:
TRUEsuccess
FALSEerror
