Watchdog Lib API
WatchDog Support Library.
Macros
#define WATCHDOG_VER_MAJ   1
 Major Library Version.
#define WATCHDOG_VER_MIN   0
 Library Subversion.
#define WATCHDOG_VER_BUILD   0
 Library Build.
Functions
void WatchdogGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL WatchdogInit (void)
BOOL WatchdogDeinit (void)
BOOL WatchdogRetrigger (DWORD Timeout_ms)
Detailed Description
Author
$Author$
Version
$Rev$
Date
$Date$
Test:
Colibri PXA320, Windows CE 6.0
Target Platforms:
PXAxxx
Caveats:
The watchdog does not work on PXA270 due to bug in the PXA270 CPU.
Library Build.
Library Subversion.
Function Documentation
BOOL WatchdogDeinit(void  )
Deactivate watchdog
This is not possible, therefore the function always returns FALSE
Return values
TRUE= success
FALSE= error
void WatchdogGetLibVersion(DWORD * pVerMaj,
  DWORD * pVerMin,
  DWORD * pBuild
returns the version of this library
Parameters
[out]pVerMajMain Version of this library
[out]pVerMinSubversion of this library
[out]pBuildBuild Number of this library
BOOL WatchdogInit(void  )
Activates the watchdog, and sets the Watchdog timer to the maximum timeout:
2^32 ticks / 3.125MHz = 1'374sec = 23min.
Return values
TRUE= success
FALSE= error
BOOL WatchdogRetrigger(DWORD Timeout_ms)
Retrigger Watchdog
Parameters
[in]Timeout_msA hardware reset will be done if the Watchdog is not
retriggered within this time [ms]
valid range: 1...1'374'389
Return values
TRUE= success
FALSE= error
