Power Management (Woodpecker and Robin)
Article updated at 26 Sep 2012
There are several ways to bring a Woodpecker and Robin Computer Module into a Power Save State.
Windows XP
Standby
You can use the following command from the command line: rundll32.exe powrprof.dll,SetSuspendState
Shutdown
You can use the following command from the command line: shutdown.exe -s -t 0
Windows Embedded Standard and XP Embedded
The following component is required: Power Management Application
Standby
You can use the following command from the command line: XpePM.exe –Standby
If Hybernation is enabled, you can use also the following command from the command line: XpePM.exe –Hybernate
Shutdown
You can use the following command from the command line: XpePM.exe –Shutdown
