How to use Character LCD
Tags
Character LCD displays a monochrome text which can be alphanumeric.
Use cases:
  • Vending machines
  • Panel meters
  • Fax machines and copiers
  • Industrial test equipment
  • and many more..
This tutorial demonstrates how to interface 20x4 character LCD with Toradex module using GPIOs. In this demo JHD204A LCD has been interfaced with Iris Board V1.1A. It is advisable to use 3.3V to 5V level translator if you want to interface 5V LCD, please note Colibri Module GPIOs are not 5V tolerant.
Schematic diagram
NOTE: Below mentioned examples can run on Colibri VF50/61 modules, for that you have to use Vybrid GPIO libraries available here.
Demo Application in C
  • Download demo code from here.
  • Build and deploy the solution.
  • Navigate to My Device > Program Files > characterlcd_demo and run the application characterlcd_demo.exe.
LCD Output
Demo Application in CSharp
  • Go to My Device > Program Files > vcsharp_characterlcd_demo and run the application vcsharp_characterlcd_demo.exe.
Following GUI will open. Enter characters to be displayed for each line in text boxes and click on send button.
  • characterlcd-vcsharp-output
    characterlcd-vcsharp-demo-output
Any feedback/question, please send us an email at support@toradex.com.
