It is possible to flash an embedded Linux image to a target module using two methods:
Note: Legacy flashing method does not imply that the embedded Linux image is legacy. There are pre-built Toradex images that are provided in both legacy and Toradex Easy Installer formats. Consult the image releases for a list of images in both formats.
Attention: If your Computer on Module is supported by the Toradex Easy Installer, the legacy flashing method is considered deprecated and you shouldn't use it.
This prepares a SD card or USB flash drive for later use on the carrier board with the module which is to be flashed.
<module-type>_<image-name>_<version>.tar.bz2
where <module_type>
is one of Apalis TK1, Apalis T30, Apalis/Colibri iMX6, Colibri iMX7, Colibri-T20, Colibri-T30, or Colibri-VF and <module_type>_LinuxImageVx.yz.tar.bz2
where <module_type>
is one of Colibri_T20, Colibri_T30 or Colibri_VF.You can find all the latest pre-built images in Binary Images, both in the legacy as well as the Toradex Easy Installer formats, or conveniently in the tables below, only in the legacy image format:
Toradex Embedded Linux Stable Releases
OS Image | Supported Modules/Download Link | Summary Overview | |
Linux LXDE Image | Apalis TK1 (2.8.7 | 2020-06-10) Apalis TK1 Mainline (2.8.7 | 2020-06-10) Apalis T30 (2.8.7 | 2020-06-10) Apalis iMX6 (2.8.7 | 2020-06-10) Colibri T30 (2.8.7 | 2020-06-10) Colibri T20 (2.8.7 | 2020-06-10) Colibri iMX6 (2.8.7 | 2020-06-10) Colibri iMX7 (2.8.7 | 2020-06-10) Colibri VFxx (2.8.7 | 2020-06-10) |
Angstrom LXDE desktop environment image |
Linux Console Image | Colibri VFxx (2.8.7 | 2020-06-10) | Linux Image without graphical user interface |
Use any FAT formatted SD/uSD card or USB flash drive with enough free space (1GB or more recommended).
Note: U-Boot expects a partition table (MBR) on the SD card or USB flash drive and the FAT partition to be the first partition!
Find the mount point of your SD/uSD card or USB flash drive by e.g. using df or lsblk:
[user@host ~]$ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p1 7582228 2808272 4773956 38% /media/KERNEL
[user@host ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 7.3G 0 disk
└─mmcblk0p1 179:1 0 7.3G 0 part /media/KERNEL
update.sh
script with the -o
argument pointing to the mount point of the SD card or USB flash drive. For example assuming the SD card is mounted at /media/KERNEL: ./update.sh -o /media/KERNEL/
At this point the SD/uSD card or USB flash drive should contain U-Boot, optionally the Linux kernel, the flashing scripts and the ext3 (for eMMC modules) resp. UBI (for NAND modules) root file system images.
