Debug config block settings
Config Block Settings
dbg.serial:     0               (Debug Serial Output)
dbg.regread:    1               (Read from persistent Registry)
dbg.regwrite:   1               (Write to persistent Registry)
dbg.watson:     0               (Enable DrWatson) (1)
dbg.watsonsize  1024            (Size in KB of DrWatson DumpBuffer) (1)
(1): Available on Tegra images, from 2.0 beta 4 on
serial: Enables(1) or disable(0) the debug output.
regread: If you set this value to 0, the system will not read the registry in the flash.
regwrite: If you set this value to 0, the system will not write to the registry in the flash.
