Carrier Board (Woodpecker, Robin)
Article updated at 27 Nov 2017
Since Woodpecker and Robin are COM Express Modules, it is necessarily to have a carrier board where the needed connectors are placed, power supply is done. etc.
Toradex Carrier boards
  • Lily, A version for Robin and one for Woodpecker available.
  • Daisy, A Pico-ITX (100x72mm) form factor baseboard for Robin.
Developing a carrier board
For most of the applications developing a specific carrier board is necessary. Toradex provides reference schematic in order to ease development and reduce the risk. Toradex may also develop carrier boards for customers.
Woodpecker and Robin Reference Documents
For detailed technical information about the components of the Robin module and the COM Express™ standard, please refer to the documents listed below.
COM Express™ Design Guide
Guidelines for designing a COM Express™ carrier board:
http://www.picmg.org/pdf/PICMG_COMDG_100.pdf
http://www.comexpress-extension.com/
http://www.nanoetxexpress.org/specifications.html
Important: Do not use a zero delay buffer for the LPC Clock. If your design has more than one LPC Clock sink, use a normal clock buffer instead.
COM Express™ Reference Board Schematics
Schematic diagrams of the Toradex Lily Carrierboard:
http://files.toradex.com/X86/Lily/Lily_V2_1_Datasheet.pdf
Schematic diagrams of the COM Express™ evaluation carrier board:
http://www.comexpress-pnp.org/uploads/media/CEVAPnPSA0_09.pdf
Carrierboards from other manufacturers
for Woodpecker
The following Carrier boards are tested with Woodpecker:
for Robin
The following Carrier boards are tested with Robin:
