  • Computer on Module
    Colibri iMX6
  • Carrier Board
    Aster Carrier Board
  • Computer on Module OS
    Linux
  • Development PC OS
    Linux
Basic UART usage - Aster Carrier Board
Attention: the Quickstart Guide for BSP 2.8, based on the Ångström distribution, is not being updated anymore. Depending on your SoM, you have different options:
Vybrid and Tegra: the information is provided as-is and still accurate, since newer Toradex BSPs are not ported to those SoMs. Just keep in mind that the Guides are not being maintained anymore, even if we find bugs or outdated instructions.
Apalis TK1 (all variants), Colibri iMX6ULL (all variants), Colibri iMX7S 256MB and Colibri iMX7D 512MB: these computer on modules are still regularly maintained in our BSPs and, to get started, you must check the software page Toradex BSP Layers and Reference Images for Yocto Project. Since Torizon is not supported, at the moment a Quickstart Guide is not available.
All other i.MX-based SoMs: you have two options to get started with embedded Linux: the first is to follow the Quickstart Guide for Torizon, which provides the greatest out-of-the-box experience, or if you choose to use Yocto, check the software page Toradex BSP Layers and Reference Images for Yocto Project.
In this lesson, you will:
The information provided in this guide is based on Toradex's knowledge base article UART (Linux).
Attention: Never connect a RS-232 output pin to a TTL input. This might lead to permanent damage.
Materials Required
  • Jumper wires
Be introduced to the UART protocol:
UART stands for Universal Asynchronous Receiver-Transmitter. These kinds of interfaces are used to achieve asynchronous serial communication between devices. The transmission speed and the data format are configurable.
There are 4 main pins that may be used on a UART interface:
  • RTS, request-to-send
  • CTS, clear-to-send
Note: The RTS and CTS signals are used to achieve hardware flow control. We will not delve into this topic in this tutorial. Therefore, we will only use the RX and TX (and ground) pins.
  • UART Block Diagram
    UART interfaces block diagram
Get used to the naming conventions:
The Aster Carrier Board offers 3 UART interfaces common to all SoMs from the Colibri family, presented in the Toradex Name column from the table below. The other columns provide information about the respective protocols, converters or electric standards in which the signals are available on the carrier board:
Toradex Name Serial-to-USB converter TTL 3.3V
UART_A X4 -
UART_B - X20
UART_C - X17
Note: UART_C is referred to as UNO_UART in the Aster documentation.
The following table relates the Toradex Name to the corresponding Linux device file:
Toradex Name Device
UART_A /dev/ttymxc0
UART_B /dev/ttymxc1
UART_C /dev/ttymxc2
In this lesson, the UART_B interface is used in the examples and the Toradex naming convention (Toradex Name) is used unless otherwise stated.
Step 3
UART signals and pins
Step 4
Connect your board's UART_B TX pin (X20.8) to its RX pin (X20.10).
  • Aster UART Wiring
    Aster UART Wiring
Step 5
From a serial terminal connected to the module, configure the UART_B baud rate using the stty command. We will use a baud rate of 9600 baud:
stty -F /dev/ttymxc1 9600 -echo
cat < /dev/ttymxc1 &
echo "Testing UART" > /dev/ttymxc1
Testing UART
Step 6
A UART loopback test can also be written in C.
License
Step 7
Step 8
Step 9
Step 10
After writing to the serial port, you can read from it. Since it's a loopback, you will read what you just wrote and save it to the buffer variable. Also, don't forget to use the standard system call close() to close the device when you're done. To avoid timing problems, use a delay between writing and reading.
Step 11
Loopback test code
Step 12
Improved loopback test
Step 13
For this example, we will call UART_B "first_uart" and UART_C "second_uart".
Connect UART_B_RXD (X20.10) to UART_C_TXD (X17.2) and UART_B_TXD (X20.8) to UART_C_RXD (X17.1).
FAQ
How can use another UART interface instead of the one used in this lesson
Can the debug UART be used for general purpose
How can I disable DMA for RX
